I think you have the wrong time zone selected. Some zones are 30 min. off the rest. just in case
Instruction book page E-23. To turn auto receive on or off. In Timekeeping mode press D (Lower right) to display last Signal screen. It should say GET at the bottom and show the last time it updated. (Or ERR) Hold down A until the receiving indicator and current auto receive setting (ON or OFF) start to flash. Press D to toggle auto receive on. A again to end.
If you tried to make it receive manually this will be turned off. If the GET screen said ERR then it did not update and auto receive would still be off. I had to do the manual thing about 20 times before it updated. A upper left C lower left D lower right A upper right (light)
The Auto Light feature of your watch has been turned on. To turn it off, press and hold the button that is on the bottom right of your watch for about 2 seconds. In the upper right of the face of your watch is a circle with some text on it. There should be a down pointing triangle in the upper right of that circle. Below that triangle there should be a dark mark before you turn off the auto light. After you hold the lower right button down for the 2 seconds that dark mark should turn off. The Auto Light feature will also turn itself off after six hours to help you to conserve your battery life.
You have the Auto Light feature on your watch turned on. The light will turn on when you rotate your wrist 40 degrees. To turn off/on, hold down "G" button for 2 seconds.
Wow, you are retarded. That's a function of the G Shock watches. I don't know who would actually use the auto light function, but its there. To turn off auto light, hold down your illuminate button for 2 or 3 seconds until you hear a beep. Holding down the light button toggles between auto light on and auto light off.
To turn the auto light switch on and off--
In any mode, hold down (L) (light switch at 6o'clock/bottom)for about two seconds to goggle the auto light swithch on(auto light swithch on indicator displayyed) or off (auto light swotch on indicator not displayed)
