I have a Uniden TRU9480. The battery stopped charging so I put in a new battery. The new battery won't charge up. I have cleaned the connections and I don't know what else to do. Any suggestions? The answering system still works fine but the hand set won't charge.
There are a few reasons why a battery won't charge. Make sure that the contacts on the phone and the charging cradle are clean. (Unplug the base or charger.) A pencil eraser is good initial cleaner; electronic contact cleaner sprays are a second option. Remove the battery and check the contacts inside the handset and the battery as well. Next replace the battery pack. If you add a comment with your phone's model number, then I can try to find the correct battery. (Stores like Battery Mart may have a compatible battery.)
The final possible problem is that the charging system is bad. If your phone has multiple handsets, try a different charger. If the phone allows you to add handsets, try getting a new handset. The new handset will come with a new charger. (I've never seen the chargers sold without the handset but you could try Uniden customer service. If the base station is the only handset cradle, you'll probably need to replace the phone if a new battery and clean contacts don't work.
If your Uniden phone is under warranty, contact the company.
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% and graduallythe charge reduces until the battery won't charge up at all. OR The batteryshows a 100% charge but when the adapter is disconnected the battery drops offto zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Check your connections on hand set and base. Wiggle the handset on base to see if handset starts charging... If it does.. clean your connections or you have loose solder connections either in hand set or Base Unit.. Give that a try..
Laptop batteries can become unchangeable if they are completely discharged, and left that way for too long. This happened to my Asus. IF you leave it charging over night and it still doesn't work you will need a new battery. If you contact the manufacture they will probably charge you over $100 for a new battery. If you use eBay, the average price is $32.
http://shop.ebay.com/i.html?_from=R40&_trksid=p5197.m570.l1313&_nkw=IdeaPad+S10e+battery&_sacat=See-All-Categories
Regards,
Chris
The green light on your charger indicates a full charge but you know thats not right since you didn't charge the batteries when they were in storage they have dropped so low the charger cannot detect them and provide a charge. The batteries will need to be replaced with new ones. Charge before use and charge for at least 20 days to get them operating at 100% now you will have to use it for those 20 days to get the batteries used to charging charge every night when you go to bed and unplug when you get up in the morning. If you do have to leave the chair for a week or so put up fully charged and charge once a week overnight. If you put the chair in storage again disconnect the batteries from the chair and store with a full charge. Hope this helps you
The base unit should not need a charge. It should be powered by the plug in adapter. It may have a battery to keep operation for a short time in a power outage. The adapter may be loose, the adapter could be broken or the plug in the phone may be broken.
