SOURCE: Kenmore 90 series washer will get stuck in between cycles
Sounds like the timer has failed. It's a common problem.
Part number 8545379, $83.69 from SearsPartsDirect.com
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
SOURCE: my series 90 washing machine stops midway through the rinse cycle
Hi, faulty timer motor or timer, knob you turn for different cycles (programs) , it's called timer, that timer usually run by small motor, and sometimes burnt out, could be electronic too, remove top back panel, look at timer, you'll see small motor, attached by two small screws, remove motor, place ohm tester lead, and check for continuity. if motor is burnt out, replace it, if your timer is electronic, you will have to replace complete timer, good luck.
SOURCE: Whirlpool Ultimare Care II washing
No you have a problem with the agitator cam assy. You can easily fix this yourself for $10.00 or less. You need to order or pick up an agitator repair kit. it will come with a new cam , 4 directional cogs (dog ears),and bearing, Simply remove the fabric dispenser on top of the agitator twist and pull ,then remove pull up on the agitator barrier cap (use soap to lube seal when reinstalling) remove the 7/16 bolt retaining the top part of the agitator.remove top part, pay attention to how the cam and dogs come out.. Install new parts and reverse order. with a little luck you should be done in 15 to 20 minutes and have a working machine Good Luck
