Question about Wicor Industries Pool & Spa
This is the pump I have can you tell me what Horse power it is?Ultimax-56-2 model CSA PUUM562H25UM8M1 UL PUUMSC2252582FR Thanks
Posted by studesh67 on
John Prohaska
    President:
  • Wicor Indust... Master
  • 1,378 Answers
What is the voltage and amp rating found on the motor nameplate?
Posted on Jan 27, 2011
How do I get my IP address for my tv
the tv picks up an available IP address automatically from a router.
it is not fixed or assigned by user.
Nov 10, 2014 | Element Electronics Televison & Video
BRUSHES FOR CUT OFF SAW # 55-6705-8
Hello. I can see why you've had problems getting this info. Here's the deal. The brushes are vendor supported by a company called JinDing. They specify that they have two or three different sizes of brushes for that model of saw. What they need from you (to get the proper part #) is either the UL code ro the CSA number as well as the model number. With all that, give them the CTC part number as well. They tell me the price range is about $10 + tax + shipping. I recommend ordering at least 2 pair, just to make it worth while. The phone number you want is 1(877) 683-2082 ext 205 (cust service).
If this helped, please feel free to rate this thumbs-up!
Thank you,
Richard
Mar 13, 2011 | Dmm 14" Cut-Off Saw
Capacities and pressures of Ingersol Rand Air compressors
Model Number: SS3J5.5GH-WB Manufacturer: Ingersoll Rand Tank Size: 8 Gallons Engine Engine HP: 5.5 HP Engine Type: Honda GX 160 Fuel Tank: .8 Gallon Pump CFM @ 90 PSI: 11.8 Max Pressure: 135 PSI Certification: UL/CSA/ASME Overview Dimensions: 43" x 18" x 26" Product Weight: 175 lbs
this can be a reference.
May 06, 2010 | Ingersoll Rand SS3J5.5GH Wb Ir Portable...
Has the IBM drive part number 32P0725 been replaced by another part number at all?
Drive Features Capacity: 146.8 GB Interface: Ultra320 SCSI Rotational Speed: 10000 rpm Access Time: 4.7 ms Type of Drive: Internal System Type: PC Average Latency: 3 ms Additional Features: Predictive Failure Analysis (PFA) Compliant Standards: CE, CSA, UL, TUV, C-Tick, BSMI
Sep 21, 2009 | IBM (32P0725) 146.8 GB Hard Drive
I have a Bestec atx-300-12az and i need to know which power supply harness to use on a Samsung model#HD103UJ hard drive.Thanks,Tony
Technical Details
  • Samsung Spinpoint HD103UJ 1 Terabyte SATA/300 Hard Drive General Features:
  • 1 Terabyte formatted capacity 7200 RPM spindle speed SATA/300 interface 32 MB buffer
  • 8.9 ms average seek time 4.17 ms average latency 3.5-inch form factor
  • Improved recording stability over temperature with PMR
  • Advanced dynamic FOD control for best data integrity
SATA Power3 Peripheral4 Floppy5 02 +3.3V (Orange)
03 COM (Black)
04 +5V (Red)
05 COM (Black)
06 +5V (Red)
07 COM (Black)
08 PG (Gray)
09 +5VSB (Purple)
10 +12V (White)
11 +12V (White)
12 +3.3V (Orange)
13 +3.3V (Orange)
14 -12V (Blue)
15 COM (Black)
16 PS-ON (Green)
17 COM (Black)
18 COM (Black)
19 COM (Black)
20 Blank
21 +5V (Red)
22 +5V (Red)
23 +5V (Red)
24 COM (Black)', CAPTION, 'Pin Signal (Color)', WIDTH, 150, BGCOLOR, '#000000', FGCOLOR, '#FFFFFF');" onmouseout="return nd();" href="javascript:void(0);">matx24pin.gif
atx12v.gif sata.gif drive.gif floppy.gif This ATX12V power supply is a 300W, five output unit with remote on/off, and UL, CSA, and TUV approvals. RoHS compliant. Original HP part number 5188-2625 used in many Media Center, Pavilion, and Presario computers. Also serves as upgrade for HP/Compaq part numbers 5189-3964, 5188-0131, 5187-5116, 5187-6114, 5188-0129, and 410507-001. Airflow drawn out of case into surroundings by 80mm internal fan. Built-in power status LED above AC inlent. 2 x 12 (24 pin) main board power connector. Includes two daisy chained Serial ATA connectors. Bestec model ATX-300-12Z CDR, also replaces ATX-300-12Z BC, ATX-300-12Z BD, and ATX-300-12Z CC. i trust this helps
Jul 15, 2009 | HP ATX-300-12Z (ATX30012ZBD) 300-Watt...
3 beeps every few minutes
That maybe a memory beep code. Turn it off and remove and re-insert the memory modules on the mainboard.
If this doesnt work, get back to me.
Feb 13, 2009 | Apex Computer Technology Apex Power Supply...
Compaq Ij300 Power Adapter
The AC adapter for the COMPAQ IJ300 is the Class 2 Power Supply, Model DND-3005, INPUT 120-127V-50/60 Hz 350mA, OUTPUT 30V---500mA, PART # 70D0209, Assembled in China 9933 per my orignal adapter for the COMPAQ IJ 300.
Jul 15, 2008 | Compaq Inkjet Ij300 Printer
PSU problem
The total connection is two part if you disconnect 20*pin one part then four part is other part. when you connect 20 pin in mother board .the four pin connect anther port. then the power supply is on.
Jan 24, 2008 | Computers & Internet
Pool & Spa Logo
300 people viewed this question
Top Wicor Industries Pool & Spa Experts
Bill Jordan
john h
David Spradling
David Spradling
Are you a Wicor Industries Pool and Spa Expert? Answer questions, earn points and help others
