My hotpoint washing machine WF560 mini load and reduced creases lights are flashing and also the on/off light is also flashing, please help. Thanks
Anonymous
    New Friend:
    Problem Solver:
Heating eliment or PCB, is this when doing a prewash? or a normal wash excluding pre wash?
if you can manualy pump out and manualy rinse and spin, my guess is heating eliment is broke £20-£30
Posted on Jan 27, 2011
2 Related Answers
Daniel S
Daniel Scott
  • 4323 Answers
SOURCE: my washing machine wf560 hotpoint,
Hi
It means that the filter is blocked. It is located under the front or rear kick strip. Please also make sure the there is no gung in the sink spigot and waste pipe is not clogged or kinked. Hope this helps...please post back for further assistance.
Daniel
Posted on Jul 02, 2011
Daniel S
Daniel Scott
  • 4323 Answers
SOURCE: my washing machine hotpoint wf560 is flashing
Hi
It means the filter is blocked. It is located under the front or rear kick strip. Please also make sure the there is no gung in the sink spigot and waste pipe is not clogged or kinked. Hope this helps...please post back for further assistance.
Daniel
Hotpoint WF541 problem
Technical Fault is Pressure switch jammed on empty: check switch & module... in laymans terms its either a blocked sump hose or faulty pressure switch/module
Mar 13, 2010 | Hotpoint Aquarius WF000 Front Load Washer
The mini load and reduced creases light flash when washing has finished, but its as though it hasn't been spun properly
I should check the filter if I were you.
Remove lower rear panel of washer, remove large black hose on bottom of drum, remove and clean filter inside hose.
Please rate my solution.
Thanks.
Nov 03, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint wf540 stopping on a rinse and spin and
check pump/filter/outlet hose for blockages. if ok, check pressure switch (disc shaped item at top of machine with 4? wires and a tube) by blowing into it gently - should hear clicks, then blow into tube to pressure chamber - should be clear.
Oct 26, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Lights flashing on WF320P
i'm having same problem people have said empty filtter but i have done that and the water is running out but still flashing
so sorry wish i could help.
Sep 05, 2009 | Hotpoint Aquarius WF000 Front Load Washer
My washing machine has just stopped working and the on/off light and the mini load light are flashing rapidly any ideas???? make ..hotpoint, model...WF560
TRY HOLDING IN THE SIGNAL LITE FOR 3 SECONDS AND THAT SHOULD TURN THE LITES OFF AND OR THE CONTROL LOCK LITE OFF ALSO!! GOOD LUCK
Jun 03, 2009 | Hotpoint WMA35 Front Load Washer
Reduce crease and mini load lights flashing on hotpoint wf541g. had pump failier and have replace with new on but still not pumping water out.
I have encountered a similar problem. The following lights were flashing on and off:
  • On/Off.
  • Reduced creases.
  • Mini Load.
I also found that previously one of the 'lifters' inside the drum had broken off and someone had tried to put it back in place and continued to use the washing machine. After a short period of time the above mentioned flashing lights began.
I first suspected the pump, but this was fine. I then disconnected the hose which connects the hole from the drum to the pump and I found a child's sock blocking the hose. I removed the obstruction, put it back together and the machine worked perfectly. I also replaced the lifter (apparently these break quite often) and the machine has been working perfectly ever since that day.
I hope this helps. Good luck.
Mar 10, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Machine freezing with three lights flashing.
HI JOHNNYHEFF,
JUST GOT A NEW HOTPOINT STARTED TEST WASH ALL THE LIGHTS FLASHED SO SWITCHED OFF TRIED AGAIN NO JOY. TECHNICIAN COME OUT SAID THE CIRCUIT BOARD WAS GONE, NOT GOOD NEWS FOR YOU BUT THOUGHT I'D LET YOU KNOW!
Oct 23, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius WF560 1600 Spin Problem
i have a aquarios wf560 machine dose anyone know where the filter is
Sep 28, 2008 | Washing Machines
HOTPOINT AQUARIUS WF 250 ON/OFF LIGHTS FLASHING
The lights are set off by the balance sensors.And if your balance sensors are  stopping    it from spinning than you first have to make sure the washer is level.You  could have bad Shocks and a bad electronic control board,.
May 05, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
543 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
