Question about Samsung SGH-X530 Cellular Phone
Reset settings my phone - Samsung SGH-X530 Cellular Phone
Anonymous
    Novelist:
  • 155 Answers
Hello
1. Power the phone on. The phone should go through the basic start-up and come to rest on the main screen.
2. Press the "Menu" button and find the "Settings" option, then "Reset Settings." You may have a "Restore Factory Settings" option here, or a more extensive menu that lets you choose what to reset, such as sound settings, display settings, phone settings or all.
3. Reset the phone by choosing "All" or "Restore Factory Settings." Press the "Yes" button when the phone asks you to confirm that you want to reset it.
4. Power cycle the phone, and when it comes back on you will be able to reconfigure your settings correctly.
THANK YOU
Posted on Jan 27, 2011
Go back factory condition
Hello Cynthia,
There are several ways to achieve this.
Reset phone
The Reset feature allows you to set your phone options back to
the factory defaults.
  1. From Idle mode, touch Menu-> Settings -> Phone -> Reset phone.
  2. At the "All settings reset to factory defaults. Continue?" prompt, touch Yes to reset, or No to cancel. Once your phone has been reset to its default settings for those selected options, it will restart itself in order to incorporate the new settings.
Restore phone
The Restore feature allows you to delete any user information
that has been added, in addition to setting your phone options
back to the factory defaults.
  1. From Idle mode, touch Menu-> Settings -> Phone ->Restore phone.
  2. At the "All settings reset to factory defaults and all user data will be deleted. Continue?" prompt, touch Yes to reset, or No to cancel.
or
Reset code
Enter *2767*3855# in phone dial.
Warning! All your data including contacts, messages etc. will be lost! Copy all your necessary data/Contacts/Messages etc. to SIM or make backup on your PC before full reset!
Dec 06, 2013 | Samsung SGH-A877 Impression Cell Phone
How can I reset my c905 to factory setup
Restore phone to factory default settings
Restoring your phone can be useful if you lend out the phone or just want to restore your phone to factory default settings and delete all user data.
To perform a master reset of settings and delete all settings and user data:
  1. Select Menu > Settings > General (tab) > Master reset.
  2. Select an option:
    • Reset settings: If you want to delete all user data, such as contacts, messages, and downloaded games.
    • Reset all: If you want to reset both user data and restore all original phone settings.
  3. Select Continue > Continue.
  4. The phone restarts.
Note: When making a factory reset of all content, you may lose content that was in the phone when you purchased it.
May 28, 2011 | Cell Phones
My Samsung sgh-a867 keeps rebooting after about 30 sec - 1 min. What do I need to do to get this fixed.
Try resetting the phone.
Steps to reset Settings
  1. From Idle mode, touch Menu >Settings >Reset Settings.
  2. Place a checkmark next to those settings ( All, Sound Profiles, Display and Light, Phone, Alarms ) you wish reset.
  3. Touch Reset.
  4. Enter your phone password, if prompted and touch Confirm. The default password is 0000.
  5. At the Reset Settings ? prompt, touch Yes to reset, or No to cancel. Once your phone has been reset to its default settings for those selected options, it will restart itself in order to incorporate the new settings.
Apr 01, 2011 | Samsung Eternity Cell Phone
Need the steps to perform a master reset on the a Sprint Sanyo Pro 700
It is important to know that resetting your phone would wipe out all the data that you hvae on the phone. It is therefore advised that you create a back-up before proceeding.
Steps to Reset Settings
Resetting the default settings restores all the factory defaults, including the ringer types and display settings.The Contacts, Call History, Calendar, and Messaging are not affected.
1.Press Menu > Settings > More... > Security.
2.Enter lock code.(The default code is last 4 digits of your phone number or 0000 or 1234).
3.Select Delete/Reset > Reset All Settings.
4.Read the disclaimer and press OK (left softkey).
5.If you are certain that you would like to restore all the factory settings, press Yes (left softkey).
Steps to Reset Phone
Resetting the phone resets all settings, including the ringer types and display settings.This option will delete all data on your phone.
3.Select Delete/Reset > Reset Phone.
5.If you are certain that you would like to reset your phone, press Yes (left softkey).
Hope this was helpful? Please comment for more information and thank you for using FixYa.
Mar 22, 2011 | Sanyo PRO-700 Cellular Phone
I need the master unlock code for my samsung sgh-a887
All I can find on this model number is a phone.
here are 2 articles I have found for you to try.
one code I found is here, perhaps it may work.
Samsung SGH-a800
*2767*637#
for just a reset here are the directions for that.
Reset Phone
This resets the phone to its default settings. User Data such as contacts, messages, pictures, videos, and music is not deleted.
  1. From Idle mode, touch Menu , Settings , Phone , Reset Phone.
  2. At the Continue? prompt, touch Yes to reset, or No to cancel.
  3. Enter your phone password, if prompted and touch OK.
  4. After the phone settings have been reset, the Reset Phone done confirmation displays. Once your phone has been reset to its default settings for those selected options, it will restart itself in order to incorporate the new settings.
Restore Phone
The Restore Phone option is the same as the Reset Phone option described above in that all settings are reset to factory defaults.However, with the Restore Phone option, all user data is deleted.
Mar 08, 2011 | Samsung Cameras
Samsung SGH-A877 Impression Cell Phone The phone kept dialing and redialing numbers
Try resetting the phone once and see if it solves your problem.
Reset phone
This feature resets the phone settings back to the factory defaults.
  1. From Idle mode, touch Menu > Settings> Phone > Reset phone.
  2. At the All settings reset to factory defaults. Continue? prompt, touch Yes to reset, or No to cancel. Once your phone has been reset to its default settings for those selected options, it will restart itself in order to incorporate the new settings.
http://resetcellphone.com/solution/Samsung/sgh-a877-impression
Feb 22, 2011 | Samsung SGH-A877 Impression Cell Phone
C905
  1. Select Menu > Settings > General (tab) >Master reset.
    • Reset settings:If you want to delete all user data, such as contacts, messages, and downloaded games.
May 05, 2010 | Sony Ericsson Cyber-shot C905 Cell Phone
MY PHONE IS LOCK AND I CANNOT UNLOCK IT. WHAT CAN I DO?
Check out this link below to download a PDF manual, software, and more for your phone. Just copy and paste into your browser.
http://www.samsung.com/us/consumer/mobile/mobile-phones/t-mobile-phones/SGH-T929ZKATMB/index.idx?pagetype=prd_detail&tab=support
Page 165 from your manual:
Reset Settings
From this menu you can reset your phone and sound settings to the default settings or perform a Master reset.
Reset settings
1. From Idle mode, touch Menu ➔ Settings ➔Reset settings ➔Reset settings.
2. Touch the check box next to each of the following that you want to reset
• All: Phone, Display, and Sound settings are returned to default values.
• Sound profiles: only sound settings are returned to default values.
• Display settings: only display settings are returned to default values.
• Phone settings: only phone settings are returned to default values.
3. Touch Reset.
Master reset
From this menu you can reset your phone and sound settings to the factory default settings.
1. From Idle mode, touch Menu ➔ Settings ➔ Reset settings.
2. Touch Master reset, enter your password, then select Yes to confirm.
The phone resets to the factory default settings automatically and when finished displays the Main menu.
Hope this helps, let me know if I can do anything else for you.
JimmyC
Oct 13, 2009 | Samsung Memoir SGH-T929 Cell Phone
HOW TO UNLOCK A PHONE LOCK
http://www.samsung.com/us/consumer/mobile/mobile-phones/at-t-phones/SGH-A867ZKAATT/index.idx?pagetype=prd_detail&tab=support
Page 73 from your manual:
Reset Settings
You can easily reset your phone to its default settings. To reset
your phone:
1. From Idle mode, touch ➔ Settings ➔ Reset Settings.
2. Place a checkmark next to those settings you wish reset:
• All: selects all fields and places a checkmark alongside all entries.
• Sound Profiles
• Display and Light
• Phone
• Alarms
3. Touch Reset.
At the “Reset Settings?” prompt, touch Yes to reset, or No to
the new settings.
JimmyC
Oct 13, 2009 | Samsung Eternity Cell Phone
How to reset my phone
Menu>>Phone settings>>Security>> Reset factory settings (default code :00000000) OR Main menu----Settings----Reset Settings----Phone Settings-----Select Reset
Oct 18, 2007 | Samsung SPH-A660 Cellular Phone
Samsung SGH-X530 Cellular Phone Logo
137 people viewed this question
Top Samsung Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
John Tripp
John Tripp
Michael Thomas
Michael Thomas
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
