House Brand Omron HBF 500 Body Composition Monitor with Scale Logo
Posted on Jan 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
"weight" shows on the screen, then CAL blinks a
Ankit Chandel
Level 2:
New Friend:
  • Expert 141 Answers
  • Posted on Feb 22, 2011
Ankit Chandel
Expert
Level 2:
New Friend:
Answers
141
Questions
Helped
29319
Points
375
Open this and free to the oil.
1helpful
What is the power of engine chevrolet chevette 1980
petrol (gasoline) engine with displacement: 1599 cm3 / 97.7 cui, advertised power: 52 kW / 70 hp / 71 PS ( SAE net ), torque: 111 Nm / 82 lb-ft
  • characteristic dimensions: outside length: 4112 mm / 161.9 in, wheelbase: 2395 mm / 94.3 in
  • reference weights: shipping weight 902 kg / 1989 lbs base curb weight: 928 kg / 2046 lbs
  • how fast is this car ? top speed: 159 km/h (99 mph) (theoretical);
  • accelerations: 0- 60 mph 13.4 s; 0- 100 km/h 14.4 s (simulation ©automobile-catalog.com); 1/4 mile drag time (402 m) 19.2 s
  • 0helpful
    Shows 0.0lb no weight
    Well I figured it out, just in case anyone comes across this. Turn it over, push the button on the top middle of the scale, hold, turn back over, wait until "C" appears on the screen, stand on scale, now it works. :)
    1helpful
    On my "Ideaworks" wireless electronic display
    After playing with the remote on this scale for about 30 minutes, I finally found out how to change this display from kg to pounds or stones. Since this scale doesn't come with an instruction manual, I know a lot of people are totally lost. OK, first click the user button once, so that the weight and goal weight show. Then hold down the clock/set button. After a few seconds the kg on the screen will start blinking. Then use your arrow buttons to switch to stones, then to pounds. The lb will show at the top of the display above where the kg was. You can also set your goal weight by pressing the set button and scanning through after setting the lbs setting. Hope this helps!
    2answers
    3helpful
    Please tell me in E-Z words how to set the clock and calendar on the Canon MP11DX calculator? Manual instructions, which I cannot locate anyway, are absolutely unclear. Please HELP!
    To set the calender: Press the Calender/Time button. Press and hold the Time Set button for 3 seconds; the first digit of the date will start blinking. Then type in the date as two digit number for the month and date and a 4 digit number for the year. Add a zero in front of the month or day if under 10. Then press Time Set again. Press the CE/C button to return to the Calculation mode
    (hold for 3 seconds)
    Thus for today [Cal/Time] [Time Set] 0 9 1 5 2 0 1 0 [Time Set] [CE/C]
    For December 1, 2010 [Cal/Time] [Time Set] 1 2 0 1 2 0 1 0 [Time Set] [CE/C]
    To set the Time from the Calculator mode, you press the Calender/Time button twice before pressing and holding the Time Set button for 3 seconds; again the first digit of the current time will blink. Then type in the time as a 4 digit number followed by the AM/PM button to switch from AM to PM or PM to AM. Then press the Time Set button again and then the CE/C button to return to the calculator mode. You will see an A (AM) or P (PM) to the right of the time as you set it.
    So for 5:06 PM you type
    [Cal/Time] [Cal/Time] [Time Set] 0 5 0 6 [AM/PM] [Time Set] [CE/C]
    I hope this helps. You can find the manual here: http://www.usa.canon.com/cusa/consumer/products/calculators/printing_calculators/mp11dx#BrochuresAndManuals as a pdf.
    (I'm using Cal/Time for the button that has an icon that looks like a 1 month calender on the left and a clock on the left.)
    38helpful
    8answers
    My Soehnle scale shows an out2 error - how do I fix?
    How to calibrate when "out2" is shown.
    With the power off andthe scale on a stable surface, hold "g" and press "on". Some number will show up, probably a negative number. Press the "on" button again and the scale should display "Zero". Wait until it says "200.0". Gently place a 200 gram weight on the scale and wait a few seconds. If your successful it will say "Pass" and your scale will work again, yay!
    26helpful
    2answers
    I need a manual for a Berkley fs50 scale
    Operating Instructions1
    A. Powering-on the scale
    1. Press and hold the POWER button for two seconds. Scale will perform a self-test by displaying four 8s for three seconds. When "0.00 kg" or "0 lb 0 oz" is displayed on the screen, scale is zeroed-out and ready for normal operation.
    B. Normal Weighing
    1. Hang fish on the attached hook. Weight is displayed in either kilograms or pounds and ounces.
    C. Switching between unit weights
    1. Press and hold the POWER and CHOOSE button simultaneously for three seconds. Unit will change from weighing pounds and ounces to kilograms and vice versa.
    D. Taring Weights
    1. Weigh a bag or container till its weight is steadily displayed on the screen.
    2. Press the POWER button once. Scale will zero-out and show "0.00 kg" or "0 lb 0 oz" and is ready for weighing multiple fish together.
    E. Holding a weight
    1. With the weight displayed on the screen, press the CHOOSE button. This will hold the current weight and is indicated by displaying an H to the left of the screen. To unlock the hold, simply press the POWER button.
    F. Storing weights into memory
    1. With a weight in the hold mode and an H displayed to the left of the screen, enter the memory mode by pressing the CHOOSE button. While in the memory mode, pressing the CHOOSE button will allow you to navigate through ten stored memories. These are indicated on the left and numbered 0 through 9. There are also 4 letters that indicate other options. An A shows the average of all stored weights. An E displays the total and a C resets the memory.
    2. To store a weight, simply hold down the CHOOSE button for three seconds. Weights will automatically store into one of the number registers. To see the numbers with their weights, simply scroll through the numbers by pressing the CHOOSE button as described above.
    G. Resetting the memory
    1. With the unit in the C mode, press and hold the CHOOSE button for six seconds and scale will reset memory and zero out. Press the POWER button and scale is ready to begin weighing again.
    H. Powering-off manually
    1. Press and hold the POWER button for 6 seconds.
    23helpful
    4answers
    How to calibrate a Pelouze model 4010 scale with a
    when i turn on my 4010.the screen display shows 4010 but thats all it does.any solution.
    Top House Brand Health & Beauty Experts
    Rob Hill
    Rob Hill
    ADMIN Andrew
    ADMIN Andrew
    ADMIN Eric
    ADMIN Eric
    Are you a House Brand Health and Beauty Expert? Answer questions, earn points and help others
