Canon imageRUNNER C3200 Copier Logo
Posted on Jan 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Its not printing shows 00020-02a - Canon imageRUNNER C3200 Copier
Anonymous
Level 2:
Sniper:
  • Expert 118 Answers
  • Posted on Jan 27, 2011
Anonymous
Expert
Level 2:
Sniper:
Answers
118
Questions
0
Helped
64801
Points
326
Change magenta drum
Xerox phaser 7760 not detect the missing fuser, image units
there is nothing to look for it told you it is past the end of it's life so buy a new unit
COLOR DOES NOT SHOW WHEN PRINTING
There should be an HP utility on your computer that will allow you to run a print head test. This should show you if the color portion of the printer is working. If it is then likely the driver on your computer has been set for grayscale printing only.
Black ink will not show up on paper
It seems print head clogged,this issue not related with cartridge, perform clean print heads 3-4 times & chk, if no result replace the print head (CN642A).. I won't suggest for manual cleaning for this print head unit.. Thanks for listening me..
86helpful
5answers
I have brother DCP 7055 it shows print unable 71 error pls suggest
I have brother DCP 7055 it shows print unable 72 & some time it show 71 error pls suggest
2answers
Key is flashing. Internet blue light is on. Printer gets signal for print job but won't print until I USB connect it to my Macbook OS 10.6.
Follow the steps below to resolve the issue
The print queue and Dock printer icon
When you start a print job, you will see your printer icon appear in your Dock. Click the Printer icon to open the print queue, which is a list of print jobs that are printing, on hold, or paused. The print queue will also display messages sent from the printer.
You can alternatively open the print queue from the Print & Fax pane of System Preferences.
printer%20queue.png In the Print Queue toolbar you have these buttons:
  1. Delete - Deletes the selected print job.
  2. Hold / Resume - Will hold / resume the selected print job.
  3. Job Info - Shows details of the selected print job, such as job name, status, Completed, Job Message, and so forth.
  4. Pause / Resume Printer - To Pause / Resume the Print Queue.
  5. Supply Levels - Will drop down the Supply Levels sheet showing you the levels of ink / toner your printer has.
  6. Printer Setup - Lets you configure the printer's name and location details.
  7. Printer - Sets the Print Queue window into Printer mode.
  8. Scanner - Visible if you have a multi-function printer connected via USB. Click it to set the Print Queue into Scanner mode.
You can see what your print job looks like with Quick Look. Click the arrow on the print job just to the left of the Status column or select the print job and press the Spacebar.
From the Print Queue menu bar, the "Printer" menu has these additional options:
  1. Customize Toolbar... - Used to add and remove item from the Print Queue's toolbar.
  2. Make Default - Will set the printer pertaining to this Print Queue your default printer.
  3. Print Test Page - Will send the CUPS Printer Test Page to your printer.
  4. Network Diagnostics - Will bring up the Network Diagnostics application, used to check each layer of your network connection.
  5. Log & History - Used to open the Console application and show you the log entries for your current and past print jobs.
  6. Show Printer List - Will open the Print & Fax System Preference showing you the list of Print Queues.
From the Print Queue menu bar, the "Jobs" menu has these additional options:
  1. Show / Hide Completed Jobs - Will alternate Show / Hide in the Print Queue all completed printer jobs and completed functions, like checking the supply levels of your printer.
  2. Show Everyone's / My jobs - Will alternate showing Everyone's / My print jobs.
You can control-click (or right-click) your printer icon in the Dock for this convenient menu:
printer%20proxy%20dock%20menu.png From the Dock menu you can see your printer's status, toggle Pause and Resume Printer, Auto Quit (once print job completes) on / off, and from the Options sub-menu you can toggle Keep in Dock on / off.
4helpful
3helpful
2answers
I have riffile my smasung ml-1640 printer cartage three time then it show red light but printer works ok, after 2100 pages printed its not working properly, when i give command to print any file no error...
By deepak_compu on Oct 06, 2009
i have riffile my smasung ml-1640 printer cartage three time then it show red light but printer works ok, after 2100 pages printed its not working properly, when i give command to print any file no error show,but print not come. and when i print a test page from printer button it gives print. but on paper write like this toner exhoasted so what i do for this problem please give me soltuion of this problem
Trying to print, but Status Paused is showing
Hi
Thanks for using FIxYa. Please turn the printer off and then cancel all the print queues pending in the bottom toolbar by double clicking on the printer logo if you want to delete all the pending printing files. Now turn the printer on. If you do not want to cancel all the printing jobs then you can double click on the printer logo showing in the right side of the bottom tool bar and then right click on the printing jobs pending for printings then click on restart printing. Issue will be resolved and it will not show ‘paused status’.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
old marine
old marine
ZJ Limited
ZJ Limited
