Samsung SH-S222A/BSBF DVDRW Drive - DVD+R 22X, DVD+RW 8X, DVD-RW 6X, DVD-RAM 12X, CD-R 48X, IDE Burner Logo
Posted on Jan 27, 2011
Cannot copy data file direct - Samsung SH-S222A/BSBF DVDRW Drive - DVD+R 22X, DVD+RW 8X, DVD-RW 6X, DVD-RAM 12X, CD-R 48X, IDE Burner
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 27, 2011
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
96
Points
5answers
Print is encrypted, nothing is readable.
If you are printing it from online, try copy and pasting the content to Word or Excel and print from there.
How to convert sdf file in xls file ?
SDF file is a compact relational database also called a SQL server database. Designed for the application that runs on mobile devices and desktop.
If you only want to access SDF files in Excel sheets then you can see your SDF files in SQL Server or Visual Studio.
1helpful
Unaible to down load vidio data from canon dc310 to my pc
Try to copy directly Your camera disc to conventional DVD, without downloading files to computer. It is possible with Nero Burning Rom in a disc copy mode. And before it, try to play an original at Your DVD player, or from the camera direcly to TV. If it works, then make a direct copy as well. Another solution is insert original dvd to computer and copy all carpets directly from dvd to HDD. Then, using MPEG Streamclip (free program) test Your files. If You can see the image - perfect. Any video can be converted a DVD format without problem.
1helpful
Dear Sir, In case there are atleast 80 files or more having same format containing datas in columns in each file with different figures, I want to merge all file in a single sheet in one shot. Kindly...
If the column names and orders are same across files, then you can directly use the MS Excel's import data function, this will do your job.
Alternatively, if you want to do it manually, import each file in separate excel worksheet using data import wizard or simple copy paste of data (in latter case you have to use Text-to-Col feature of excel), and then manually append all figures (copy-paste in one go) to any external excel sheet.
Then finally, export/save as that external sheet to any filename of your choice.
Hope this helps.
Thanks.
1helpful
Canon SD870 - Unable to copy AVI files to desktop
You need video editing software to copy .avi files to.
XP and Vista have that onboard.
Either direct the data to it or import the data from the individual program.
If that does not work, then you have a transfer problem between Camera and PC.
Try a card reader, that will prove it.
How do i get pictures and onto my mp3player
These are the manufacturer's (RCA/Thomssen's) exact words:
For users running Windows XP with Service Pack 1 and above:
  1. With your device connected to your computer, click on “My Computer” and then click on the icon for your device. If you see a folder labeled “DATA”, you must copy the photo files you want to view directly into this folder. Folders containing photos cannot be copied to the “DATA” folder. Photo files must be copied directly to the “DATA” folder using no other folder.
  2. If you do not see a folder labeled “DATA”, then copy the photo files you want to view directly to the device. Folders containing photos cannot be copied to the “DATA” folder. "
-Tha Mp3 Doctor
Hey
Make sure the image file is in JPG format, or the player won't be able to read it.
With your device connected to your computer, click on My Computer and then click on the icon for your device. If you see a folder labeled DATA, you must copy the photo files you want to view directly into this folder. Folders containing photos cannot be copied to the DATA folder. Photo files must be copied directly to the DATA folder using no other folder.
If you do not see a folder labeled DATA, then copy the photo files you want to view directly to the device. Folders containing photos cannot be copied to the DATA folder.
Rca M4002A MP3 player
Rca opal
Transferring files via Windows
Explorer (Drag-and-Drop)
In Windows XP (with Windows Media
Player 10 or above installed)
In Windows XP and when Windows Media Player10 is installed, the player is connected to the
computer in MTP mode. In the Windows Explorer,when the player is opened, the “Data” and
“Media” views will be displayed for the player.The Data folder is used to manage data content
on the player, such as text files. The Media folderis used to manage media content supported by
the player for playback, such as mp3 and wma.You can copy files to the player through Windows
Explorer (drag-and-drop). Picture files should be copied to the “Media” folder for viewing while
video files can not be dragged and copied to the “Media” folder directly as only .SMV files are
supported. The video files must be converted and transferred via RCA Video Converter for playback
(refer to page 19). Alternatively, you can transferthe converted video files to the "Data" folder via
the Windows Explorer (drag-and-drop).
You can copy files to / delete files from the player through Windows Explorer (drag-and-drop), but
you cannot open or edit the files directly from the player. If you want to edit the files, you will
need to copy the files from the player to another location (drive) in the system.
I was able to locate the manual for you...It will provide you with more information for your device..I hope this helps...
http://support.rcaaudiovideo.com/manual.aspx?product=187
P.S. Please rate accordingly...
Thank you
Computerrep
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
