The static noise on lcd monitors are made by some capacitors due to uncalibrated settings inside the unit itself. You may try adjusting the contrast and brightness levels of your lcd monitor. If problem persists, have it replaced (assuming it is still under warranty). Then again, if the display output is unsatisfactory, have it replaced as well.
I hope this works for you. Good Luck!
Mongkey
"Understanding explains better..."
