I have a Mitsubishi WD-65837, its 14-16 months old. The picture has been getting darker and darker for about a week now. Is it as simple as a new lamp?
1. Lamp is nearing end of life and may dim just before total failure.
2. A few of these models have 2 mirrors(check with Mitsubishi to see if yours is one) A large mirror in back (never gives a problem and do not try to clean it. Some idiot in these sets used a small mirror inside that the optical unit shines the picture into (wedge shaped mirror and small) and it is facing up----the fans intake air from the front of the set around this mirror--it gets coated with lots of dust---Picture can loose up to 70% of its brightness and clarity if that mirror is dirty--looks like 20 year old set .
If you do not wish to check with Mitsubishi GOOGLE THE MODEL NUMBER with "mirrors" to see.
If it has 2 mirrors I can tell you exactly how to get at it.
Brian, See my answer to Brenda, the question before yours. My TV did the exact same thing in September. Time for a new bulb, before it all goes black in a few day!! Better hurry, too!! EBay or 'ShopJimmy" will fix you up with a new bulb. "Bulb only" is cheaper and a few muniutes to swap over. Entire bulb assembly costs a few dollars more, but then all you do is slide old one out and new unit in.
The Ballast that ignites the Lamp could cause the Lamp to fail and/or cause a buzzing noise. That being said, the Color Wheel in the Optical Block assembly could also cause a similar symptom. If Mitsubishi would be willing to help with the Lamp cost, I would call a local Mitsubishi repair facility to install it and see if the noise is still there and find out exactly what is causing it. Mitsubishi Customer Service Phone number is 1800-332-2119.
I hope this helps,
Skyassoc
Yes this is burn in and replacing the crts that have the image burn is the only fix. There is no lamp in this set. There are 3 crts and not cost effective to replace them.
More then likely your 2005 MODEL has a bad "LIGHT ENGINE". Call an Authorized Service Center and have them give you an estimate, then call MIT's and try to get them to give you a "CONCESSION". It's costly. Good Luck, big IRISH.
I have a two and a half month old Sharp, LC-19SK24U-W. It was fantastic with fantasic, clear, beautifully colored picture until two weeks ago. All of a sudden, the picture starting getting darker and darker. Nothing had been adjusted from day one when I set up contrast, etc. This comes and goes but most of the time is an issue. I can make it a bit lighter but then it is so fuzzy and grainy it is a very poor picture. Also, while this began, one time the television turned itself off and then back on without a power surger or anything.
We replaced a 6 month old lamp with a new lamp, but picture is still darker
