Check this site for
RC Helicopter (model RC8703) user manual
https://groups.google.com/forum/#!msg/alt.paranormal/gh4P9D2Xlz4/0-LtPy-Zi3MJ
batterys turn off when not flying
should charge when plugged into toy
green light is fully charged /on
SOURCE: The instructions say that the
It's a typo in the instructions. The helicopter must be turned off to be chaged
SOURCE: my rc helicopter can not fly it spin in floor
Hi
This type of helicopter uses a fixed pitch blade. Have you recently replaced one or all the blades? If the blades are correctly positioned then once the motor comes to speed, the pitch of the blade creates enough lift to overcome the force of gravity. The problem you're having can only be that the motor is not coming to speed or the blades have been replaced but the pitch is now at the wrong angle.
SOURCE: Brookstone Silver Bullet Helicopter: When I
This is a battery fault, unfortunately pretty common. How old is this helicopter? It may still be under warranty.
Let me know, there is not really much of anything you can do on your end... you are doing everything correctly for sure.
Tim
SOURCE: Purchased Helicopter MINI AIR WOLF
My wife bought one of thsoe for me for my birthday. I charged it for an hour - turn off the helicopter power switch and plug in the charge plug on the control - the control must be on. anyway the thing doesn't have enough lift to get off the ground. It just skitters along the ground. Also the tail rotor doesn;t do anything. The parts list identifies a tail motor so it should do something. Going to return it to the mall. That's a hassle! I would try to fix the tail motor, but if the thing can'e even get off the ground what's the point? Any info send it to rsockey at yahoo dot com.
SOURCE: my rc helicopter wont fly high?
flew at first hit sealing won,t fly now hit the trim button,s but still wont fly
