Question about Philips Vacuums
We need to replace the Fan Blades on our Phillips Fan as they heve got very fragile and they are breaking up!
Posted by kaypet78 on
Mack Baxter
    Master:
  • 383 Answers
Yes-- This is the big disadvantage of this type of Vacuum--
Stones and sand wear heavily on that impeller turning a very high rate of speed.
This can be a tricky job----- depending on how long this fan has been on the motor shaft-- and if water has been passed thru this joint--
-- It will take a complete disassembly of the power section of this vacuum--
(I have seen a few times, when the impeller could be just hit a solid blow in the 'un-tightening direction, and the impeller spun right off- -- Very god, if you can get that response! :-) )
Most of the time one has to tear the motor apart, and get a solid grip on the armature (Clamping it firmly-- but gently in a vise -- and then beating on the impeller to remove it.
Naturally-- you would need to have the correct impeller ready to spin right back on the shaft-- for the old impeller will be ruined in removal. Be sure to put some 'never-seize' on the thread, to make it easier to remove NEXT time!
How old is the machine?
Ever consider trading it in on a new type of Vacuum?
Let us know if we can help more-
Mack B
Posted on Jan 27, 2011
Fan housing broke on our xl21 600ecc
If you take it to an Oreck dealer for repair you will probably get both because the fan housing usually comes with a new fan. Usually a fan housing will only break if something was picked up that the blades flipped it into the housing with enough force to crack it. You may find that depending on the dealer it may not be covered under warranty. I work at a dealer on weekends and work on these machines and have seen this frequently, I would recommend replacing both if you are able to get them separately.
Mar 27, 2014 | Oreck XL21 Bagged Upright Vacuum
Hi My bissell proheat 2x 9500 is making a loud noise when the brushes are moving. I replace both belts and cleaned the brushes. Can you think of anything else it could be.
Hello there,
Try using other brush attachments, as broken bearings in a brush attachment will cause noise. If these troubleshooting techniques do not work, you may need to service the engine.
Remove the filter and bag of the machine and make sure that they are not clogged or full of debris. Clean any filters according to the instructions for your model or replace the bag. Excessive debris will make the engine run noisily.
Inspect the hose of the vacuum and remove any large debris that may be clogging the inside of the tube. Large amounts of dust, as well as stones or other hard materials that bounce, may cause a loud noise in the engine.
Remove the housing that conceals the engine of your machine and inspect the fan for damage or clogging. Remove any dirt or debris that may hinder the movement of the fan. Inspect the fan for any damage such as bent or excessively sharp blades. Replace the fan blades as needed; contact your vacuum manufacturer if the fan is damaged. The replacement part will include instructions.
Tighten the fan with a ratchet if it is loose on the assembly. A loose fan will make a rattling sound as the motor revs.
Wipe dirt and dust from the frame of the engine. Large quantities of dirt or dust around the motor can cause it to overheat, which can cause vibration and loud noise.
Look for corrosion around the engine. If the engine is corroded, it must be replaced.
Grease the bearings of the engine if you hear a grinding noise from the vacuum. Greasing is often performed through ports in the engine, or by removing the bearings. However, the actual greasing method is model-specific. Consult your owner's manual or send the vacuum to a service professional for this service.
Inspect the inside of the vacuum cleaner for other worn parts or broken pieces. Worn or broken pieces can cause loud noises to occur. Remove the broken part and order new materials from the vacuum manufacturer or take the machine in for service.
Hope this information was helpful to you. All the best. Elect_Comp
Sep 05, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
My fan is installed and it wobbles it is anchored properly from the box but the pole has a little play from the top not tightly secured The eletrician had to change the downrod was is on the fan at the...
Hi marilynh57....
Try removing the fan blades and putting them into different positions.
This will sometimes solve your wobbling problem as some fan blades are heavier than others and this causes the wobble you experiance.
Please take time to rate me
Aug 17, 2011 | Vacuums
I have a 18 yr old Admiral DH359 demudifier. When I turn on the dial (switch) it gives a humming noise buy the blade does not rotate. After about a minute or two it shuts off because of condenser over...
The problem with your unit is the fan. The engine behind the blades have gotten spoilt hence its inability to roll the blades. Usually when the engine of a fan is spoilt as a result of the coil the engine still tries to move but due to the bad coil the engine hums but does not come to a start. The fan is meant to be the main component which regulates the temperature of the unit if the fan does not cool the unit then the unit will overheat and go off. Simplest solution is to extract the entire fan plus its engine and get ? replacement for it. If you have the required expertise to open and reassemble the unit you can do this yourself otherwise get an expert to carry it out for you. Hope this solution has been helpful?
Jun 23, 2011 | Vacuums
I need part a break down for electrolux model 1205 vacuum cleaner with factory part numbers, I would like it to have the motor and fan parts break down and numbers to be able to replace the fan blades, I...
The motor and fans are a single unit/assembly. Schematics and parts lists are only available to authorized service techs and franchise owners.
The company that made this machine is now Aerus. You can purchase the correct parts through your local Aerus Electrolux dealer. They know the parts to order for this machine and will provide the correct ones.
http://www.aerushome.com/storelocator/
Apr 07, 2011 | Vacuums
Wine cooler has error code on bottom half "E4". What are the possible problems?
Sound like a problem with the fan unit; the connectors to the fans get moisture in them and corrode.
Just stripping the wires and hard connecting them, only tool needed is a phillips screwdriver. There are 3 connectors on the side to remove the control panel shelf. Its a pretty simple job.
If this not solve it, need to replace the fan.
Hope helps.
Mar 31, 2011 | Vacuums
How do you clean the fan blades on a humudifier
Hi and welcome to FixYa. I am Kelly.
I do this all the time and it works well for ALL types of aluminum fan blades on any appliance.
Use an older piece of Scotch-Brite with soap & water (So you do not scratch up the blades) then wipe it off with a damp rag then a dry rag. Just make sure you do NOT get water in the motor bearings. Place the blade your cleaning below the 3 or 9 o'clock positions to avoid introducing water into the motor bearings. Also do your best NOT to bend the blades in the process of cleaning.
Thanks for Choosing FixYa,
Kelly
Feb 16, 2011 | Vacuums
I have a Eureka The Boss Power sweeper but can't find my Owners Manual. It seems to have lost some vacuum power. It doesn't pick up cleanly, leaves a streek of residue behind and seems to be blowing air...
Blowing air out of the right side? As in blowing air out of the right side of the hood? If its a light stream of warm coming out of the vent in the hood that's normal, its exhaust air from the motor. Now, clogs can occur at the outlet from the fan chamber. Remove the bag from the base of the machine via two screws. See if that area is clear and the tube going up into the bag unit is clear as well. Now, if the fan chamber is clear, inspect the fan for breaks or missing blades.
Dec 12, 2017 | Eureka 1934 Bagged Upright Vacuum
The fan blades under the motor are broken i like my dirt devil triangle please help fix it.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=758276
Generic problem for all Vacuums
Posted by roadrunner19 on Jul 08, 2008
The fan blades under the motor are broken I like my dirt devil triangle please help fix it.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Changing the fan should not be a problem; it happens every so often if you pickup something big and the plastic fan breaks. The cost to repair is about $10.00 to $20.00 plus labor and you can repair it yourself if you are handy or take it to a local vacuum cleaner dealer in your area and they can perform the fan replacement. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://royalvacuums.com/ Customer Service 1-800-321-1134
Hours are: 8:00 AM to 7:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 08, 2008 | Vacuums
Vacuums Logo
195 people viewed this question
Top Philips Vacuums Experts
Tim Venetis
JonSnell Electronic
JonSnell Electronic
Attique-ur-Rehman
Attique-ur-Rehman
Are you a Philips Vacuum Expert? Answer questions, earn points and help others
