Kenmore 96213 Electric Kitchen Range Logo
Posted on Jan 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dont preheat - Kenmore 96213 Electric Kitchen Range
Anonymous
Level 3:
  • Kenmore Master 43,501 Answers
  • Posted on Jan 27, 2011
Anonymous
Kenmore Master
Level 3:
Answers
43501
Questions
0
Helped
10838302
Points
101584
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Oven takes too long to preheat or dont preheat at all
you may need a new element, its possible that it is burnt out.
4helpful
The oven preheats, but then "cools down" before I
Most likely the problem is your bake element. When the oven is preheating it uses both the bake and the broil element. When it's done preheating it uses only the bake element, so the broil element is heating it up, and since the bake element is not working the temperature drops until it starts preheating again.
1helpful
2answers
Got a 06 corolla verso D4d T180 sometimes struggles to start. Can take 10-15 seconds of turning over until it goes. It doesn't happen all the time. Dropped it off at a local garage for a day and it...
do you get into car, push key into ignition, then put seat belt on then turn key over???if you do it in this order should there still be a starting fault,could be a preheater going south....the car is fitted with automatic preheaters,they start work when you close the drivers door.(some toyota dealers dont know this)
SLOW HEATING OVEN
you may want to check your broil element
turn the unit on and wait a few minutes
see if you can feel the heat from the upper broiler elemnet
some model use both elements to preheat
i dont have your productiuon number so i cannot be sure with your model
anyway
14-20 mins is the industry standard for a 350 preheat...
Whirlpool accubake doesn't preheat properly
Are both of your heating elements lighting up when you are preheating? It sounds like the oven thinks it is pumping power into both elements and one isn't working. Oven elements are generally easy to remove and replace!
Preheat worksoven wont bake
hi The range timer is usually located in the control panel on top of the range. If you suspect the timer is faulty, don't try to fix it yourself. Remove it and take it to a professional service person for testing. Here's how to remove the timer:
Step 1: Remove the back service panel to the control panel and release the spring clips that hold it in position, or remove the retaining screws.
Step 2: Push the timer forward to release it.
Step 3: Remove the electrical lead wires from the timer housing. If, when disassembling the timer, you notice that the electrical wire terminals look burned, remove these leads and buff the leads and the terminal points with fine steel wool. Burned and/or dirty terminals can cause the timer to malfunction, but a good cleaning can solve this problem.
Step 4: Replace the old timer or install a new one of the same size and type, if this is necessary. Connect the new timer the same way the old one was connected.
37,008.4x - PEST_FAULT_PREHEAT_HEATER_DISCONNECT
PEST - Preheat Heater Disconnect The Preheat heater is not drawing the expected
power from the supply.
1. Run the Preheat Heater test.
2. Check the preheater wiring.
3. If the test fails, replace the preheater.
Unexpected message: 6B22
That is a pre heater fault.
Preheater exit sensor in unexpected state during fault.
Preheater exit sensor in unexpected state during stage.
  1. Check system grounds.
  2. Check the Drum Maintenance Kit NVRAM contacts during oiling for continuity.
  3. Check the waste tray.
  4. Replace the Preheater ( REP 2.0.17).
B2M
B2N
B2P
B2Q
The preheat flag tripped unexpectedly while picking paper from Tray 2.
The preheat flag tripped unexpectedly while picking paper from Tray 3.
The preheat flag tripped unexpectedly while picking paper from Tray 4.
The preheat flag tripped unexpectedly while picking paper from Tray 1.
  1. Test the Preheater Sensor using Service Diagnostics.
  2. Check system grounds.
B3M
B3N
B3P
B3Q
B3S
B3T
The preheat flag timed out waiting for the paper picked from Tray 2.
The preheat flag timed out waiting for the paper picked from Tray 3.
The preheat flag timed out waiting for the paper picked from Tray 4.
The preheat flag timed out waiting for the paper picked from Tray 1.
Preheater sensor timed out during stage.
Top Kenmore Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
