Question about Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc
I went to use my spa heater a raypak RP 1200 or 2100 residential unit. While viewing the digital control/thermastat unit I pressed the black button (that normally allows to toggle to spa and pool) to automatically spark start heating is now no longer allowing me toggle to these positions. Is my control panel/thermastat longer good? Please advise thank you.
Posted by reidtustin on
3 Related Answers
John Morganti
  • 864 Answers
SOURCE: raypak pool heater piliot light on heat will not turn on
Make sure that gas control knob is set to ON (counterclockwise). Make sure that ON/OFF switch is ON. Check that temperature setting is high enough to call for heat. Make sure pool pump is running and water is flowing to unit.
If not above there is a diagnostic procedure on page 33 of manual at:
http://www.raypak.com/uploads/6000.52AG.pdf
Posted on May 30, 2009
kapishtech
raj somaiya
  • 2272 Answers
SOURCE: I have a Raypak RP 2100 R405 pool heater. When I
Yes its faulty PC board.As no Power Coming from the board.Click this link directly to get PC board. http://www.a1poolparts.com/-strse-Heaters--dsh--Parts-cln-Raypak/searchpath/1015892/start/61/total/103/Categories.bok ------------------ To confirm the fault in PC board. Check for exact 24 volts on PC board. One yellow and One Blue wire. --------- For checking transformer check 120/240 volt to transformer(time clock circuit breaker wire connections). Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Jul 10, 2010
Kieran Ruppert
  • 990 Answers
SOURCE: raypak 2100 pool heater " PRS " diagnostic reading
This is low pressure. Start by checking your baskets for clean then be sure to clean the filter. Then make sure the by-pass valve is closed and lastly if your pump basket is cracked or broken check to be sure nothing is clogging your impeller.
Posted on Sep 19, 2010
Saying off on timer but unit has no timer?
This is a good one? I would call the Raypak technical support number and they should be able to help you. I hope this helps.
Please vote on this answer. Thank you.
Aug 26, 2011 | Raypak 266K BTU Digital Residential...
Jul 10, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
RayPak 2100 series digital pool heater Code "EOL".
press the mode button until the display reads "off". Remove the four screws holding the control cover on. Swing panel down so that the back of the board is visible. Press the mode button until "RESfl" appear. Press and hold both "up" and "down" buttons for 5-7 seconds until three dashes appear (---). This resets the fault history and clears any stored faults.
Sep 05, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Pool Heater igniter wont light
Hi check out the power phile should be between 300 to 500 mille volts
Jul 11, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc Logo
165 people viewed this question
Top Raypak Pool & Spa Experts
Paul Carew
Marvin
Marvin
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
