Question about Patton Electric Heating & Cooling
Is there a recall on patton heater mod puh9000.mine shorts out? thank you
Posted by oakleyego on
Rich Landrum
    Brigadier General:
  • 4,736 Answers
Yes, there is/was a recall on some Patton Heaters, but I don't recall if your model # is one of them. For more info search Google for Patton Heater Recall Notice and you'll find the correct site.
Posted on Jan 26, 2011
I have an PATTON PUH 9000, it works when it want too on/off never really heating anything.As there is a RECALL on this unit, where do i get it fixed or my money back?
Here's a link to the site that has a phone number to call concerning the recall of last December.
Use it to determine if your model Patton heater was included in the recall.
http://thestir.cafemom.com/home_garden/113974/huge_walmart_heater_recall_over
There was also a recall in 1985.
Feb 10, 2011 | Patton PUH9000-U Heater
Comes on for a sec. then goes off and on
Just answered your question. You posted it twice.
Feb 02, 2011 | Patton PUH9000-U Heater
Comes on then goes off (stay on for a few sec.)
Your Patton Heater may be on the Voluntary Safety Recall List. For more info call Patton Electric Co. toll- free at (800) 528-6050. You will need your Model # and Serial # before calling.
Heater starts but only top coil heats up then it shuts off in a few minutes
This heater may have been part of a voluntary recall. For more info click on the link below. If the link doesn't work, copy and paste it into your web browser.
http://www.cpsc.gov/cpscpub/prerel/prhtml84/84025.html
Jan 25, 2011 | Patton PUH9000-U Heater
I purchased a Patton heater PUH9000 in March 2006. I never opened the box until the other day 1/15/2011 when my blower moter on my furance stopped working. I unpacked the heater and pluged it in........
If it is the same as mine it takes a minute or two to start after you plug it in...this is a safety thing,in case it tips over...if it is tilted to much it will shut off...but will sart back up in a few minutes...
Jan 18, 2011 | Patton PUH9000-U Heater
I purchased the Patton PUH9000 heater last year. I puts out a lot of heat at first, but shuts itself off after about 5 minutes, then cycles back on after a couple of minutes. Is this normal operation? I...
My Patton PUH682 utility heater from 2011 is otherwise in excellent condition but Auto Safety Shut-Off seems to be a design problem. My overheat sensor quickly shut off the unit when surrounding air was cool. It is inside the bottom of the fan box wired between the on/off potentiometer and heating coils.
I identified it by turning on the heater and watched the metal contacts separate as it tripped. On my unit, the defective overheat sensor is hardwired. Since it was otherwise useless as a heater, I decided to jerry-rig it and hope for the best. I pried back the sheet metal edge of the fan box and wrapped the sensor with electrical tape. Then I took a very small squeezable metal paper clip and lined it with electrical tape. I clamped it over the overheat sensor and it fits perfectly to prevent the metal plates from separating. Now the heater works the way it should. The cable, coils and plug don't overheat on Hot setting and it runs continuously.
Jan 11, 2011 | Patton PUH9000-U Heater
CAN THIS HEATER CAUSE AFIRE AND IS THIS HEATER ON RECALL PATTON PUH680-U
I do not know if this heater is on any product recall but we have used patton heaters for years and pretty much have had good luck with them. However there is a fire hazard present if you set or store combustibles to close to the front.Tip over switches don't always work and I would never recommend using a heater of this type in a unsupervised area.I hope this is of some help to you. Thank you and happy holidays.
Dec 20, 2010 | Patton PUH680-U Utility Heater
Puh 9000 works great for two minutes then shuts off turn it off for five then it work for two minutes and so on can anybody please help
sounds like u have a safety switch going out try to fin the one thats cutting the unit off try bypassing hem one at a time until it stops and replace it do not leave it bypassed!!!
Feb 24, 2010 | Patton PUH9000-U Heater
I purchased a Patton model PUH682 in October
Does anyone have any info on whether the PUH682 was actually recalled?
Dec 27, 2008 | Patton PUH680-U Utility Heater
Space heater will power up, but not start,
These fans have a safey feature (sensor) that shuts the heater off if it is tipped over. It sounds like this component is not functioning correctly - may be set wrong and will not allow the heater to turn on unless you shake it to reset the sensor. If it is still under warranty return heater, if not call Patton and ask for help.
Mar 28, 2007 | Patton PUH9000-U Heater
Heating & Cooling Logo
470 people viewed this question
Top Patton Electric Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
Are you a Patton Electric Heating and Cooling Expert? Answer questions, earn points and help others
