Jakks Pacific Spy Kit Logo
Posted on Jan 26, 2011
Spynet video watch won't hold charge. tab is removed, have tried reset button. will only switch on when connected to usb.
2 Related Answers
Anonymous
  • Posted on Dec 26, 2010
SOURCE: Spynet Video Watch not working - battery was
OMG!!! I am so upset right now my son's watch was on the computer charging and now all it has across the screen is spynet ....I HAVE RESET IT AND IT GOES BACK TO THE SAME THING!! I AM RETURNING IT TODAY!!! WHAT A DISAPPOINMENT
Anonymous
  • Posted on Dec 27, 2010
SOURCE: New Spynet Video Watch will
The external battery pack supplied in the box with the watch works in "Try Me Mode". There is a reset button on the back of the watch. Reset the unit and the USB port will work. I have two units that had exactly the same problem. Both are charging now!
What other chargers for Spynet watch that work?
All you need is a mini-USB to USB cable. Then use your laptop or any open USB port to charge.
My spynet video watch won't charge.
If you have a Iphone charger base unplug the wire then just cilp in the long retangular part of the usb charger (also works with a nitendo charger) then plug itno the wall connected to the watch. not everyone needs a computer used to charge it!
My spynet won't download missions
IM having the same proplem help us
3helpful
My son's spynet watch has stopped working. Have tried to charge it using different usb, but not even registering as plugged in on the computer. Anyone else had this problem? Think will have to return it,...
Hi there we had to take back his first spynet watch because the speaker decided not to work then we took back a second spynet watch because it would work when it felt like it...our son really liked it too, however after the second watch we didn't wan't to keep having problems so he decided to buy something else...gave up trying to get on their website because it kept freezing and couldn't download spy missions so we had nothing but problems with it ...hope that helps
12helpful
2answers
Spynet watch will only turn on when connected to computer usb. I set time and date and display shows that the battery is charged. when i remove it from computer, nothing works. i tried the reset also.
Make sure the plastic tab is completely removed from under the store battery pack. My tab broke and we had to take the watch apart to remove it. Once we did this, the watch worked.
Hope this helps.
I bought our son a Spynet Video watch for Christmas and we charged it but when we removed it from the charger, it turned off and wouldn't turn on. I then thought maybe we needed to download some kind of...
A bit late to the party, but two things come to mind. If the watch is new old stock with a few years on it, more than likely the battery is bad, it won't charge any more. Also, the power supply may be bad, I use 5 volt one amp charger, also, the manual says to charge it with the screen on, I tried that, and the battery will never be fully charged because the screen being on drains the battery faster than the charger can charge it.If the watch is working but the battery is low, connect the charge cable to the watch, then to the charger, otherwise the charger will pull the battery down too. So, let the screen go blank, then charge it, I have tried this method multiple times, and every time, assuming the battery is good, it fully charges in few hours. If you are adventurous, you can upgrade the battery to 450mah, it's a little bigger than the one it comes with, but lasts a lot longer, only a small amount of modification to the plastic strips made into the watch back need to be done, simply remove the strip closest to the electronics and it will fit just fine.
31helpful
3answers
New Spynet Video Watch will not charge. Will only turn on with charger attached.
7helpful
3answers
Spynet Video Watch not working - battery was removed fine but will not charge properly and have to change time and date everytime plugged in USB slot again to charge. Is this just a piece of **** I should...
Dec 26, 2010 • Toys
Top JAKKS Pacific Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a JAKKS Pacific Toy Expert? Answer questions, earn points and help others
