Expert
- Posted on Jan 26, 2011
Re: I have a garland oven model st286 it wont light even...
Instructions
Access
the burners inside your oven by removing the access panel in the front
of the oven or by opening the broiling drawer, depending on your
particular model.
Determine
if the pilot itself is lit, since some ovens have a small flame on the
pilot at all times that then grows and extends to the burner when the
oven is turned on. The lack of a pilot flame indicates the oven
thermostat is malfunctioning or there is a problem with the gas hose.
Check the pilot itself to see if it is clogged with debris or grease
that could be preventing the flame from staying lit.
Determine
if the pilot flame will grow if it is lit by turning on the thermostat.
If the pilot flame doesn't extend, the thermostat itself likely needs
replacement. If the flame is extending but the gas valve is not
opening, the safety valve could be dirty or defective. The flame should
be blue in color. A yellow flame indicates the pilot is dirty and is
not burning hot enough to get the main burner to ignite.
Light
the burner on the top of the oven with a match if the igniter doesn't
appear to be effective. If it lights manually but will not light
automatically, the igniter is likely faulty. Do not do this if there is
a heavy smell of gas in the kitchen, since there could be a risk of a
fire. In that circumstance, turn the oven off, ventilate the room and
call a technician.
Listen
for any sounds of gas hissing or a clicking sound indicating the oven
is trying to turn on. If there is no response from the oven at all, the
gas may not be functioning properly and will need to be examined by a
technician for safety purposes
