Question about Home
I just bought the GE Shower Water Filtration System and i have a handheld shower head. Will that work for it or does it only work for a normal shower head?
Posted by lchristie23 on
Rich Carothers
  • 65 Answers
Only on normal head.If you have normal set-up hand held diverts before filter.From the stand point of a 35 yr master plumber,your wasting your money,unless you gulping a lot of water while you shower.Lots of gimmicks out there,like drain cleaning chemicals complete waste of money
Posted on Jan 26, 2011
Januar Sam Amberto
    Habit-Forming:
    New Friend:
  • 37 Answers
Based on my old shower, it just for normal head. Maybe the same with your shower filter. If you found it doesn't work, you can find the shower filter that fits to your needs here http://www.showerfilterstore.com/ there you can find a wide range of shower filter types for different size of showers. Visit the online shower filter store to find out their products. May this helpful for you.
Posted on Nov 03, 2016
Triton shower faults
If its a trickle occasionally its normal, when you turn off shower the water is still in pipe right up to shower head, it cools down, contracts and backs away from the head, when house gets warmer water expands up to the shower head and trickles out.
Dec 14, 2013 | Home
Why does the water not flow from shower valve when turned on?
Do you have water coming out of the tub spout and not the shower head? If so how does the water get directed to the shower head,is it by pulling up the diverter on the tub spout?If water is still coming out of the tub spout then the diverter is bad and the tub spout needs to be replaced.
May 09, 2012 | Danze & Single Handle Tub And Shower...
The pipe that has shower head does not fit tightly into the facuet; I am installing a new facut with a hand shower and a shower head system
Try screwing it in opposite of normal threading. Left to tight not right to tight. Usually with anything liquid especially water connections threading is opposite.
Mar 05, 2011 | Franklin Decor Bathware Shower Rod
Hot Water inconsistent
Something you can do, following your fathers logic,   is to attach a hose to the drain of the tank and run water from the bottom of the tank into a drain untill all the sediment is removed (Water runs clean). This is normally done once a year as preventive maintenance  on all tank type water heaters. The logic sounds good to me.
Feb 16, 2009 | General Electric GE SmartWater Household...
Water pressure drops after a few seconds to almost nothing...
In the hand held shower head where the hose attaches to shower head. In the head there could be a flow restrictor. It may be rubber or plastic. In some cases you can remove it, or check if something is blocking it. Also try running the shower without the head on to see if there is some debris in the hose, and to check your water flow.
Jan 29, 2009 | Water Pik Waterpik& Elements& Handheld...
Kohler K-9511-BN MasterShower Shower Arm & Diverter Doesn't Work
As a helpful hint , on these models, When installed some plumbers or home owners use plumbers putty to seal the threads and in some cases tape.
Most of the time the putty or tape gets pushed through the system if too much was used.
Check by removing the shower head and testing the pressure and blowing anything else through, then checking the head itself for foreign objects.
Kohler has a cleaning and care page on thier web site if it needs cleaned.
Jan 10, 2009 | Kohler K-9511-BN MasterShower Shower Arm &...
Getting handheld showerhead plus rainhead - which valve? - a pressure reliefvalve or thermostatic valve
I installed a 2 thermostatic valves in our shower. Two of us can use both showerheads simultaneously without being frozen or scalded.
Kind Regards,
IT_handyman
Oct 25, 2008 | Pioneer 2 Handle Satin Nickel 6" Rain Head...
Home Logo
249 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
