Question about Lexar FireFly 2GB USB 2.0 JumpDrive
Dont registry - Lexar FireFly 2GB USB 2.0 JumpDrive
Posted by reivaj_0427 on
PUT A DVD IN TOSHIBA LAPTOP and it wont play back
For this issue i am providing two options.
1.You may run the hyperliknks provided below.
Hyperlink to microsoft automatic assistance
Hyperlink to Cd drive autofix
If it fixes the problem no need to follow the below mentioned step.
2. This problem is caused by two Windows registry entries that have become corrupted. To fix the problem, you have to use Registry Editor to delete the corrupted Registry entries. To use this method, you must be logged on to Windows as an administrator.
For this if you are using windows xp then the path to open registry editor will be:
Windows XP loadTOCNode(2, 'resolution');
  1. Click Start, and then click Run.
  2. In the Open box, type regedit, and then click OK.
  3. In the navigation pane, locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  4. In the right pane, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 7.
  5. On the Edit menu, click Delete.
  6. When you are prompted to confirm the deletion, click Yes.
  7. In the right pane, click LowerFilters. (dont panic if you dont see lower filter)
    On the Edit menu, click Delete. (or simply right click and select delete)
  8. When you are prompted to confirm the deletion, click Yes.
  9. Exit Registry Editor.
  10. Restart the computer
Now If the operating syatem is windows vista or windows 7 then please follow the below mentioned steps.
Windows 7 or Windows Vista loadTOCNode(2, 'resolution');
  1. Click Start Collapse this imageExpand this image vistastartbutton.jpg, and then click All Programs.
  2. Click Accessories, and then click Run.
  3. Type regedit, and then click OK. Collapse this imageExpand this image securityshield.jpgIf you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
  4. In the navigation pane, locate and then click the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
  5. In the right pane, click UpperFilters.
    Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 8.
  6. On the Edit menu, click Delete.
  7. When you are prompted to confirm the deletion, click Yes.
  8. In the right pane, click LowerFilters.(dont panic if you dont see lower filters)
  9. On the Edit menu, click Delete.
  10. When you are prompted to confirm the deletion, click Yes.
  11. Exit Registry Editor.
  12. Restart the computer.
May 30, 2011 | Toshiba Computers & Internet
I dont have a registry key to activate my registry reviver pc clean,pls send me some key licensed,thank you
download registry reviver from the below given link and you wont need the key..
http://www.filesonic.in/file/40148809/Registry_Reviver_1.4.50.rar
Mar 24, 2011 | Computers & Internet
I download a software fix my registry, then i install after i download, when i run the software they ask me to input a registry key, but i dont receive a registry key.
Alternatively, you can use other Registry fixing software/utility. I have come across a Registry Tool, which is effective to fix common Registry issues. Its Free, small size, easy to use and completely safe. Click here to download CCleaner. Install CCleaner, Click 'ISSUES' and 'SCAN FOR ISSUES' and then click 'FIX SELECTED ISSUES'
Make a backup of the registry and proceed. You may proceed without registry back, if you like.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Dec 20, 2010 | Computers & Internet
My windows vista dont have internet and sound
Check ur sound card information by doing this
Click on start menu
Click on Run
Type dxdiag, enter
Click on the sound tab
There is button of test direct sound click on this check if there is sound
Check ur registry. Check if the sound registry key is enabled or disabled. There could be an error in registry, run registry cleaner reg in out to scan for errors. Open Internet Explorer
  • Open the Tools menu
  • Select the Internet Options menu item
  • Open the Advanced tab
  • Check the box next to "Disable script debugging"
  • Remove the check next to "Display a notification about every script error"
  • Click the OK button
  • reset all setting, clean registry key for internet explorer use registry cleaner reg in out to scan ur error
Sep 07, 2010 | Microsoft Windows Vista Ultimate Edition
My computer will not let me get in to my control panel,help,or computer, it says error-50 or i dont have permission
It looks like the error in ur registry because of invalid registry errors so make ur registry error fix by using reginout registry cleaner
Aug 31, 2010 | Computers & Internet
My screen keeps freezing
ur screen freezes and all u can do is reboot pc ? if that, i had same problem. I repaired it by instaling registry cleaners... Try getting Aregente Registry cleaner.. its tottaly freeware and u dont have to pay for anything.. If that doesnt ( but should work) go to start menu, click on run, type ''msconfig'' and just shut down programs u dont want to use.... hope i helped. if not write.
Feb 26, 2010 | Acer Aspire 5500 5570-2609 Laptop
Registry Cleaner
well i can help to hack this software
this is the direct links to download the full version of the software
for the portable version take this
http://rapidshare.com/files/234920300/Portable_RegistryEasy_v5.1.rar
or
http://www.easy-share.com/1905266353/Portable%20RegistryEasy%20v5.1.rar
or download the software and his serial number
http://kewlshare.com/dl/008ce4de9476/Regi_Eas_Sa_20_05.rar.html
I DONT CARE ABOUT THE LAWS THE GOUVERNEMENT AND MICROSOFT AND ANY SILLY THING
DONT LEARN TO HACK BUT HACK TO LEARN
DONT FORGET TO RATE IT FIXYA
presented by YAMICAZANOVA
Jun 02, 2009 | QuickStart PC Cleaner XP (798936829016)...
Lexar FireFly 2GB USB 2.0 JumpDrive Logo
19 people viewed this question
Top Lexar Electronics - Others Experts
Ekse
Lawrence Oravetz
Are you a Lexar Electronics - Other Expert? Answer questions, earn points and help others
