THe problem can only really be with the clutch master cylinder. What you describe sounds like the master cylinder is not relieving pressure and this is building up in the salve cylinder, applying pressure to the pressure place and causing the clutch to slip. Can you make the problem go away even temporarily, if you open the bleed screw on the slave cylinder? You say that the free play is correct, but is the master cylinder returning fully to its released position?
