Cars & Trucks Logo
Anonymous Posted on Jan 26, 2011
Setting clock on 2006 Pt crusier - PT Cruiser Chrysler Cars & Trucks
Jeremy W.
Level 3:
Top Expert:
  • Chrysler Master 5,332 Answers
  • Posted on Jan 26, 2011
Jeremy W.
Chrysler Master
Level 3:
Top Expert:
Answers
5332
Questions
0
Helped
2057527
Points
17799
Clock Setting Procedure (digital clock page 242 of your owners manual)
1. Press and hold the time button until the hours blink.
2. Adjust the hours by turning the right side Tune/
Audio control.
3. After the hours are adjusted, press the right side
Tune/Audio control to set the minutes. The minutes will
begin to blink.
4. Adjust the minutes using the right side Tune/Audio
control.
5. To exit, press any button/knob or wait 5 seconds.
SETTING THE ANALOG CLOCK (page 238 of your owners manual)
To set the analog clock at the top center of the instrument
panel, press and hold the button until the setting is
correct. The clock will adjust slowly at first and then
quicker the longer the button is held.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
2006 pt crusier runs cold @ 60 mph runs normal at idle can not use ac
if ac not working could be out of gas..compressor stops working when the pressure is lost
check for a .leak or regas system
have the cooling system /heater pipes flaps etc checked
My 2006 Pt crusier battery light on... check battery and its good... Check the alternotor and its good..(Reading 14.3v) error code P068A
I do not have any info for this code.po68a,Are you sure that its right! check the plugs and fuel filter for the bogging issue. Repost if needed. God-Bless!
2006 pt crusier won't shift out of low
You could try the linkage cable from the shifter(under the hood). It could be alot of things. Is it auto or manual trans? And what do you mean by wont shift? Is the the shifter moving from P,R,N,D, ect... or the transmission is not shifting into a higher gear?
How do I reset security system 2006 pt crusier
Lock the car down. Open the door with the FOB or key. This should reset the security.
1helpful
PT Crusier battery light randomly comes on.
You could find that the brushes in the alternator are worn or sticking. either way require alternator removal and dismantle
1helpful
How to change a water pump for a 2006 pt crusier
you must remove the timing belt cam gears and rear timing cover recomend replacing timing belt tensioners and all idler pulleys at same time, (this job takes me 4 hours and i remove the radiator condensorassembly to make it easier) you could damage you engine if you dont install your belt correctly.
My horn quit honking on my 2006 chrysler pt crusier..
find the horn ,it should be at the front possibly behind the bumper ,run a wire direct to it and see it works ,if it does work then its the wiring in the steering wheel ,but as this vehicle no doubt has an air bag then entrust this job to a garage because if you get it wrong the air bag will explode ,expensive job to say the least
Where is the horn located on my 2006 pt crusier non-turbo.
Horn is located on the right side frame rail. pull the inner fender and you will see it.
DC
Top Chrysler Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Chrysler Expert? Answer questions, earn points and help others
