Question about Lionel New Haven Freight Train Set
My new lionel train slows down on far side of the track
Posted by ronzo69 on
  • edoptician Feb 21, 2019
    add another power feeder or two one every 10-15 track sections may sound like overkill but will even out the voltage.
ltd1217
  • 40 Answers
There is bad contact in the track connections. You can sand the track connection sites. Another method is to run another power wire to the other end of the track where the train slows down. Even better is 3 or 4 evenly spaced power wires from the transformer to the track.
Posted on Dec 05, 2013
5 Related Answers
Anonymous
SOURCE: lionel train won't reverse
there should be a switch under or in the cab section that turns off/on the reverse function.
Posted on Dec 25, 2008
Anonymous
SOURCE: Lionel train power issue
Answer a number of questions:
Is the tranformer power adequate for the train and is it a working tranformer?
Will the train run by connecting the wires directly to the two points of the train (wheels and center rail connector)?
Are the tracks new?
Is the lockon new?
Posted on Jan 07, 2009
Anonymous
SOURCE: Need help setting up Lionel North Pole Central
I had the same dilema and trains are not new to me. Look under the piece of straight track that has a notch in it for the wiring. There will be a clip to hold the wire and a piece of plactic that looks like a block. One either side of that is a metal tab that one end of the wiring slides over. Actually each piece of the Fastrack has one of these. Only one has a notch but you can notch any one.
MHC
Posted on Dec 04, 2009
Anonymous
SOURCE: WE are trying to get our lionel holiday train
There is no on/off switch. Remote will give no indication of working. Try putting engine and coal car only and try. I have had this train set for two years and the remote tends to work whenever it wants.
Posted on Dec 27, 2009
Anonymous
SOURCE: My New Bright Holiday Express train set is 10
Make sure your track is clean. take a green scrub pad and rub the track to clean off any tarnish
Posted on Dec 28, 2009
The Lionel lines train is going too slow and it
time to clean & lube your train & track.
here's a couple link's that should help :
Maintaining Your Lionel Trains
Cleaning Track
Nov 11, 2014 | Crafts & Hobbies
Lionel legacy will not run more than 2 trains
see pages 44 & 45 of attached pdf to figure out your power requirements for all locomotives, lamps/light bulbs & accessories.
compare total needed to power output of your transformer, if total is less that output of transformer, clean wheels, roller pickups & track.
if total is greater than output of transformer, you need more power/larger output transformer. lean wheels, roller pickups track.
http://www.slsprr.net/history/1954LionelTrainsAccess.pdf
Apr 05, 2014 | Lionel Crafts & Hobbies
Lionel toys
see attached pdf.
Jan 19, 2014 | Lionel Crafts & Hobbies
Lionel polar express train is stopping on the track, then becomes disabled
Replace all the batteries, then keep the remote close to the
train. if it's too far away, it will shut down.
Jan 06, 2013 | Lionel The Polar Express Train Set
I just bought a new lionel o guage remote control track section. My train can run around the oval 3 or 4 times and the uncouple button will cause a coupler to uncouple properly. Then the magnet in the...
sounds like a contact issue clean all connections make sure they fit tightly when a bad connection occures it will cause metal to heat up check both sides of the circuit with an ohm meter
Sep 04, 2012 | Lionel Remote- Control Track with UCS...
How often should tracks be cleaned. Engine slows down after running for a while
It depends upon how much you run your trains. Run your finger or clean cloth on the rail. If you see a dark mark your tracks need cleaning. You can also run another set of wires from the transformer to the spot on the track furthest from the transformer. You can even run a third or fourth equally spaced apart if you have large loops and long and heavy trains.
Dec 04, 2011 | Lionel 40 Watt Transformer Train Set Track...
I HAVE A LIONEL 2-4-2 POSTWAR WITH SLOW SPEEDS. ANYONEHABE ANY IDEA OF WHY?
Possibly in need of wheel/pickup cleaning or lubrication.
Also possible that your track need cleaning.
Oct 19, 2011 | Lionel Trains Classic Freight Train Set
I have a Lionel ZW transformer older version 1955-1956, And lately my train loses power at one area of the track and then regains power again. This happens on both the outside and inside tracks.
This does not appear to be a problem with the ZW. The XFMR does not know anything about train location on the track. It appears to be a track connection problem on the center or outside tracks or both. One way to identify a bad connection is to take a parallel wire from the common and hot terminal of the ZW and connect directly to the area of track where the train stops and slows down. If this cures the problem then I recommend checking the tightness of the three track connections. For both FasTrack and Tubular, crimp slightly the pin receiving holes in the end of the track.
Note: For both tubular and Fasrtrack it is recommended that common track power for any one section be input to the track at more than one point. In this way one bad outter or center conductor won't cause the train to slow up or stop.
If FasTrack, you can solder directly to the tabs on the track underside for a permanent connection.
Aug 22, 2011 | Lionel Postwar Parts Zw-99 Transformer...
Need lionel trains on track instruction manual for nintendo DS
I have uploaded the On Track manual to scribd.com.
Look here:
http://www.scribd.com/doc/76894727/Lionel-on-Track
or search for lionel_on_track.pdf
Nov 23, 2010 | Lionel Trains: On Track for DS
Lionel New Haven Freight Train Set Logo
1,303 people viewed this question
Top Lionel Crafts & Hobbies Experts
Tom Chichester
Bill Boyd
ray gallant
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
