Hi, My DSTV decoder is not responding to my remote, the red light for EXIT(TV2) comes on when I press any button, but nothing happens to change what I want to be changed, please help sort this out
Posted by eprumdeen on
kz101
Press the shift button, its stats flashing than press the info button (tv1) works every time
Posted on Feb 08, 2011
  • 3 more comments
  • bundubabe Jun 02, 2011
    Sorry to tell you this, but it does NOT work every time. I've have tried this many, many times.
  • MAN_UTD-WP Jun 08, 2011
    i agree, i'm having the same problem with my remote and shift button (until it flashes) and presssing info (tv1) or exit (tv2) does not work. help please
  • bongani Jun 17, 2011
    REMOVE THE BATTERIES AND PUT THEM BACK AGAIN
  • Ekemini Robert Feb 19, 2019
    I know of a website that will help. Go to Fix My Dstv Remote. They will also show you how to repair your remote by yourself.
  • Vusi Gumede
    Vusi Gumede Feb 03, 2020
    Kz101.... Thank you. Mighty simple
mickeymean
    New Friend:
It worked, like magic, the remote problem has started for a while now n was very annoying. I'm very grateful!
Posted on Sep 30, 2011
Timileyin Olanipekun
    New Friend:
When my dstv remote was locked. I pressed 'Shift' key and immediately pressed the 'Exit' key.
Please note that, you don't press the two buttons mentioned above together.
Also, the decoder I used it on is not a 'PVR'.
It worked.
Posted on Oct 24, 2016
Dstv decoder is not responding to remote control. what my be the problem?
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Mar 28, 2015 | Televison & Video
My TV is not responding when I press my DSTV remote
Dec 10, 2014 | Televison & Video
Dstv A4 remote manual,how to switch to tv2
For TV2 press Shift, then Exit
To switch back to TV press Shift, then Info
Apr 05, 2013 | Cars & Trucks
Dstv remote not working on any blue dials? Two tv's in separate rooms, one pvr decoder. Only the red dial works on both tv's & both remotes are working & both tvs responding properly.
Is this a newly installed system? If both tv's are responding to the same remote setting (red in case), it means both tv's are set to the same channel. The tv that is connected to the decoder directly (via AV cables, I presume) is supposed to respond to if the remote is set to red. In order for the second tv to respond when the remote is set to blue, you need to tune the second tv until you find the picture of tv2 (the decoder transmits both tv1 and tv2 on the RF/coaxial output and it seems that your remote tv is tuned to tv1 instead of tv2).
Apr 02, 2013 | Televison & Video
My remote control for tv #2 does not respond and i want to know what to do. i bought a new one what should i do
Hi there, Cheri Torres with DISH Network Customer Service here. I came across your post and wanted to see if I could help. If the old remote was not responding to your TV2 anymore you may want to try replacing the batteries first if that does not work the next step would be to try readdressing the remote to the receiver. You can try readdressing both remotes to get them to work with your DISH receiver box. I will list the instructions for readdressing your TV2 remote here for you. I hope you find these instructions useful and if you have any other questions or concerns feel free to email directly at [email protected]
Instructions for addressing the remote to the receiver
  1. Take your TV2 remote to your receiver box location.
  2. Go to System Info screen.You can do this by pressing the system info button once or by pressing the menu button twice on the TV1 remote.
  3. Once you are in the system info screen you will see primary remote address (TV1) and secondary remote address (TV2).
  4. Hold down the SAT button until all mode lights light up.
  5. Enter a number between 1 and 15 using the numeric keypad on the remote.Change the number in the small white square to something other then what is already listed.
  6. Press the pound (#) button.
  7. Once the SAT button blinks three times, press record. Note: If successful, the number selected in step 5 will appear in the System Info screen under Remote Address.
Mar 08, 2011 | DISH Network IR Remote Control
Dish network control not working on 2nd. tv
You have a dual receiver and 2 remotes. make sure that receiver is in dual mode. That you press the sat key on remote 2 if it will still not operate take remote 2 to the receiver. With remote #1 press the menu button twice you should then be on they system info screen. Pick up remote #2 press and hold sat key until it blinks press record 3 times . press red power button and if tv2 light goes off and on the remote should work again for tv2 . Use remote #1 press select exit screen,
Jun 02, 2010 | DISH Network IR Remote Control
Can you buy a universal remote for TV 2 to change the channels? My remote for SAT DISH stopped working the lights on the top come on but I can not change the channel, view the guide etc...
The remote is an Ultra High Frequency remote and most universals are IR MAKING THEM INCOMPATIBLE.
Take the TV2 remote into the TV1 location and using the TV1 remote press MENU-MENU. You will now have a screen up that has remote addresses at the bottom. Take the TV2 REMOTE AND PRESS AND HOLD the SAT button on the upper left of the remote until all lights on top illuminate and release. Now key in a two digit number between 1-16 that is not either number on the screen currently and press the pound sign. The SAT button will flash three times now press the record button until the remote addy for tv2 changes to the new number.
You can cancel out of all of these screens with the TV1 remote. Now go to TV2 see if it works. If not try at the receiver. If it works there have Dish send you a new remote.
Thanks for using Fix Ya.
Feb 01, 2010 | DISH Network IR Remote Control
Tv2 light does not come on
hi hammonhph! I will be more than glad to assist you in this concern. Lets program the remote for tv2, lets make sure that the battery's are brand new, please go to the front panel of the receiver, make sure that u have the remote2 with, turn on the the tv1, you got picture, on the front panel of the receiver, you got 1 green and the blue light is off.. push the power button on the front panel of the receiver once to turn off the green light, once its off the tv will show a black, blue or snowy screen, push the up button on the fron panel of the receiver until it shows the system information screen, look for the primary and secondary remote address, primary and secondary remote address should show a number on the white box ex.. 1 and 1 on the green box, secondary is ex 2 on the white box and 2 on the blue box, how to reporgram the remote to the receiver.. press and hold the sat button and wait until all lights lit up, once it all lit up, release it and press any number from (1 to 15) but for this ex is press 9, then press the pound button (#) that is under number 9, once you press the pound button the sat button will flash 3 times and then press the record button once, record button is under the cancel button or view tv button, once you are done check the secondary remote address, it should be 9 on the white box and 2 on the blue box, save the settings by using the remote 1, selct done on the screen and it will go back again to black, blue or snowy screen, press the sat button once on the remote 2 and the big red power button, the blue light should turn on, just in case the blue light dont turn on, press the power button on the front panel of the receiver for 10sec to reset the receiver, it will acquire the sat signal and go to a progress, and it will download the programming guide, check if blue light is not on, press the big red power button on the remote2 to turn on the blue light and it should work. if just incase the blue light dont turn on, the remote is bad and you need to call 1-800-333-3474 for the replacement of the remote..please feel free to get in touch if you have any query..
Jul 06, 2009 | DISH Network 322 DTV Receiver
Tvs sync together
The receiver seems to be in single mode. On the right side of the receiver press the front panel. A small pop open door will open and inside there will be a MODE button. Press this button and ensure both the green and blue lights are lit on the receiver. If they are now but weren't earlier this should solve the issue however there may be another issue.
Take the TV2 remote to the TV1 location associated with that system. With the TV1 remote and TV on press menu menu on the TV1 remote this will bring you to the System Info Screen. Near the bottom of the screen there will be two remote addresses- primary=TV1 and Secondary=TV2. Using the TV2 remote press and hold the small clear SAT button until all light across the top light up. Now key in a two digit number that is different from the original secondary address at this location and also different than the address for TV1. Now press the pound key and the SAT button will flash thrice. Now press the record button a few times until the secondary address changes to the number you selected. Once this is done you can exit out of all screens on all receivers and go to the TV2 location that was having the issue and it should be resolved. I hope this resolved your issue and thanks for using Fix Ya.
Feb 10, 2009 | DISH Network ViP622 DVR DTV Receiver /...
Hi,my brand new UHF remote wont operate the #2 tv??
Go to the tv 1 location with your TV2 remote. Turn TV1 on and using TV1's remote press menu-menu. You will be at the System Info Screen. Take TV2 REMOTE and press and hold the SAT button on the top left until all buttons on the top light up. Release the SAT button. Now key in a two digit number from 1to 16 and press the # key. The SAT button will flash three times. Now press the record button until the remote address for TV2 changes to the number you chose. When accomplished exit out of the screen with th TV1 remote and you should now be able to control TV 2. As a precaution ensure the remote antenna is on the back of the receiver. If you still have difficulty it may be required to move the remote antenna closer to TV2. I hope this answers your question. Thanks for using Fix Ya and let me know if I can of further assistance.
Dec 12, 2008 | DISH Network DVR-625 DTV Receiver /...
Televison & Video Logo
8,506 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
