Hi, You have to set the subwoofer setting
in you system .for that do the following. 1 .For the remote control, press
and hold the TUNER key for more than 3 seconds to switch to receiver
mode.
Press the SETUP key to enter the
SETUP mode and select SETUP SYSTEM using up arrow or down arrow Select SP SETUP and press the
SETUP key again so that the speaker system indication "SP SYSTEM"
scrolls across the display. Press up arrow or down arrow to
select OTHERS and press SETUP key press the up arrow or down arrow
to select the SUBW ON and press SETUP key exit the setup and try. Is the
subwoofer is working or not
p { margin-bottom: 0.21cm; }
ok
