SOURCE: Low spare fault in a 2005 Jeep Liberty, tire is at rated pressure.
Wow another great problem by a dodge product i would check for a recall on the sensor switch
SOURCE: tire light flashing on 2009 suzuki sx4
open your owners manual. if you havent already and see if there is a reset proceedure if so and light is still on go to a firestone or dealer and see if you may have a faulty tpms (tire pressure monitor system). or you may just need there tool to reset light. and yes it might cost you somthing to do it.
SOURCE: 2004 jeep liberty overhead console reads ''tire sensor bad/missing
If the spare has been off the tail gate,make sure the valve stem is at the 9:00 position . Fixed my "tire sensor bad/missing" in my 04 Liberty
SOURCE: How to take off a tire on a Jeep Liberty Ubran Terrain Stroller
If you have the model with the inflatable bike tire as a wheel, then there should be a metal locking pin wrapped around the plastic top of the wheel, you should be able to see the end of the pin sticking out (about a half inch to an inch) right below the plastic part that is at the end of the wheel. Use a pair of needle nose pliers and pull that metal pin strait off, it is held on with a pinch grip, so you don't need to twist (that could bend your pin). After the metal pin comes off, you can just take the wheel off. Then to put it back on just place the wheel back on the metal wheel bar and replace the locking pin by just pushing it on, no pliers needed for this part.
SOURCE: Tire pressure warning light goes on when tire pressure is ok
if your tire have an electronic valve (TPMS) which means there is a sensor connected to the valve, one of these sensor are defective.
