Question about Whirlpool Duet GHW9150P Front Load Washer
"control locked" light is on
Posted by melfwoods on
Anonymous
    Sergeant:
    Champion:
  • 263 Answers
Press the lock button and hold it for 5 seconds to unlock it.
Washer repair in Mission Viejo, CA
Appliance repair in Mission Viejo and Orange County, CA
Posted on Jan 26, 2011
5 Related Answers
prem mathew
  • 1294 Answers
SOURCE: "Control Locked" light is on - how do I turn it off?
Hold down 'end of cycle' button at right side of panel, for 3 seconds.
Posted on Mar 25, 2009
MNfisherman
Nate Stansfield
  • 11896 Answers
SOURCE: The control lock light is
The door will have to pried open and door switch will have to be tested or replaced. You can use a multi-meter or ohmmeter.
Worst possible cause is faulty eprom or control board but usually is faulty switch or door sensor.
Posted on Jun 27, 2009
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: me washing machine has a light that says control
You may have inadvertently locked the control panel. The Control Lock is actually a safety feature that allows the consumer to lock the control panel to prevent small children from manipulating the controls. It can inadvertently be set following a power outage, or by leaning against the control panel. The following link explains how to turn the feature on/off:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
These instructions are printed on the front panel of the appliance and in the owner's manual. If this does not correct your problem, then you may have a more serious problem than a simple operator control issue. If you need further assistance, please let me know. I hope this corrects the problem for you.
Posted on Dec 30, 2009
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: How do I unlock the controls on the washing
The Control Lock is a safety feature that enables the consumer to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance. This can usually be reset and does not require a technician.
With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. It can inadvertently be set following a power outage, leaning against the control panel, or pressing and holding the wrong button. This is usually not an indication of a malfunction.
If this is a Whirlpool manufactured front loader, the following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
These instructions are also printed on the front panel of the appliance and in the owner's manual.
If this does not correct your problem, then you may have a more serious problem than a simple operator control button issue (such as an operator console problem or main control board issue). Please post back and let me know if you need further assistance. I hope you find this information helpful.
Posted on Apr 26, 2010
Anonymous
SOURCE: unlock control lock in washing machine, whirlpool, duet
my whirlpool heaavy duty 9Kg is locked so I can't unlock it, I need help please
Posted on Aug 22, 2010
Control locked light is on, washer won't work
If this is a Maytag Epic, Whirlpool Duet, or Kenmore Elite, the following link explains how to lock/unlock this feature:
Apr 05, 2013 | Washing Machines
It won't work with the "Control Locked" light on
What is the model number of your unit?
Nov 23, 2012 | Washing Machines
The "Control Locked" light is
The Control Lock prevents unintended use of the washer. You can also use the control lock feature to prevent unintended cycle or option changes during a cycle. When CONTROL LOCKED is lit, all buttons are disabled except for Pause/Cancel and Start.
You can lock the controls while the washer is operating.
To lock the controls:
Select and hold DRAIN & SPIN for 3 seconds. The CONTROL LOCKED status light glows.
To unlock the controls:
Select and hold DRAIN & SPIN for 3 seconds or until the CONTROL LOCKED Status light turns off.
Mar 31, 2011 | Washing Machines
The status light says "control
Thank you for using FixYa. The " control locked " is a safety feature to prevent the inadvertant use of the machine by a child. To unlock the controls press the "end of cycle "button for approximately 3 seconds until the "control locked " indicator light goes out. If you have young children in your home and want to lock the controls press the "end of cycle" button again for three seconds.
Please post if this solution has been helpfull
Thank you
Duncan
Mar 04, 2011 | Whirlpool Washing Machines
How do you remove the control lock when "end of
To unlock the controls: Press and hold the End Of Cycle Signal button until the Control Lock light goes Off.
To lock the controls: Press and hold the End Of Cycle Signal button until the Control Lock light comes On.
Feb 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
"Control locked" light is on. Machine will not
Press and hold the button thats says control lock//that will unlock or lock the control panal...If it helped please vote need more help please ask good luck
Feb 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The "control lock" light is on steadily and it
Did you try and hold the lock button down for 4 seconds?If that will not work try to unplug it and plug it back in.
Jan 29, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The "Control Locked" light is on and I can't get
have included a portion of the owners' manual that covers how to turn on/off the control lock feature. Follow these instructions and if that does not work your washer may have a stuck button on the UI (User Interface).
Jan 21, 2011 | Whirlpool Washing Machines
I have a whirlpool duet washing machine and the "control locked" light is on. I cannot remove it or get me machine to work
Press and hold the "END CYCLE" button for three to five seconds, it will clear the lock.Let me know if this helps
Jan 20, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Light reads "control locked" and washer won't work
Please Turn On your washer and hold the END OF CYCLE button for about 10 seconds and that would surely unlock your washer.
Dec 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
56 people viewed this question
Marvin
Marvin
Michael Thomas
Michael Thomas
