Question about Sony Televison & Video
Have a 2006 Sony LCD Bravia 46" TV. Receipt from
Posted by botncstrr on
Anonymous
  • 312 Answers
I don't know the relationship that Cosco has with their customers however the best way to get the CORRECT model number is directly off of the back of the TV. The model number you have is not complete. It should have something like a "KVR" or at least something beginning with a K.
Hope this helps,
Best Regards,
Mark
Posted on Jan 26, 2011
How to do default settings on sony bravia kdl-46s4100
If there is an answer to this question, you will most likely be able to find it on AVSFORUM dot COM - once there go to the LCD Flat Panel Displays section and then search or scroll through the list of models. The Bravia kdl-46s4100 is approx 6 yrs old, so what you're looking for is going to be somewhat buried and by this time the discussion thread may even be closed, but whatever information is there should be extensive, as this was a popular model when new. Note also that the "46" in the model number refers only to the screen size (46") so information for any KDL-xxS4100 (where xx = the screen size) should be relevant to yours. Hope this helps.
Sony Bravia KDL-46Z4100 46 in. LCD HDTV TV does
Probably its not a problem. On the menu You should have a Headphone audio level control (when needed you can mute the set speakers and still have headphone audio).
1helpful
Problem with Sony Bravia 46" TV (Model
blow out fan in mother board tower mother is over heating and not geting enough of air leting the mane chips over heating makes computer stop so it doesnt catch fire.
Moving country with Sony Bravia KDL-46W4100
What is exact model number of your Sony TV to check its specifications that it will work on 230V 50Hz
I have a 2004 Sony LCD projection TV. The set
It is symptom of weak Lamp (bulb) that requires replacement.
You can buy Sony original lamp from Sony Accessories Store.
Lamp required for KDF-42WE655 part number is as follows..
A1606034B LAMP BLOCK XL-2100U
Sony Bravia 46S2010 no picture only glows but, only sound on
sound like you had problem with the lcd display panel. The Tcon had problem that attack to the panel.
Televison & Video Logo
Top Sony Televison & Video Experts
Ekse
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
