Hello Laura Clark - Does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if water pumps out. If it does not, the unit could possibly be experiencing an issue with the pump, door lock assembly or timer. Since it is such a complex unit, I suggest contacting a professional to move forward accurately
Hello Penny Kelly - Typically when the water temperatures are wrong, this is usually due to the hoses being connected to the wrong valves. Usually error code E70 or E76 will appear. However, you have already checked the hoses to make sure they are on the correct faucet, connected to the correct valve and that the hose has no kinks or restrictions. I would suggest contacting a professional to move forward accurately since the temperature sensor may be faulty.
