Televison & Video Logo
A
Anonymous Posted on Jan 26, 2011
TV was fine then suddenly no picture, still have sound but no picture.
Anonymous
Level 2:
New Friend:
  • Expert 36 Answers
  • Posted on Jan 26, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
36
Questions
Helped
8882
Points
115
If is a lcd tv the issue could be the inverter board or one of the lcd bulbs has stop or vcc which is 24 to 30volts that goes to the inverter is not found if its there check the fuse on the inverter if its a plasma the y-sustain board may be out there is a chip called the pmc (power modulator chip ) if is shorted the first sign would be a blown chip on the vcc side 180volt if thats the case the board is shorted needs to be replaced
Testimonial: "Hopefully"
  • Anonymous Feb 04, 2011
    Dont know if this will add to the possible solution but from other forums I read and researched a lot of people that had no picture but still had sound, had to replace their t-con boards. Not saying this would do the trick but just trying to help.
Tv has power no picture or sound
this is a proper electronic part failure this will require to be fixed by a proper tv technician as no body can guess ..call a qualified professional and get it repaired .ram mistry EMAIL [email protected]
Envision LCD TV L32W698 has no sound suddenly
Check to make sure its not muted, if not then your main board most likely has failed
TV has sound but no picture...
This is a pitcure tube problem, either you buy another picture tube and change it on your TV or if this is under warranty better to send it back to the manufacturer and have this one repair.
No sound on 50 inch hitachi tv
Have you checked other inputs with a known good program source? Mute button on remote?
My tv has picture, but no sound (lots of hash sound)
should replace capacitor ( c 1010 marked on board if it is a M134C chasie also (c 1013) both capastors are 10 mfd at 16 volts. Also check (Q603) rca part number 266897 could be bad.
1helpful
2answers
No sound through ps3 hdmi
I have sound on video 2, and when on a static channel but not on the usual channel 3 which is TV. Just stoppen working one day and cant figure it out... Please help!
Audio ok, but Video goes from color to black.
the tv turns on fine, but after 5 - 30 min or so, "sometimes MORE " the picture all of a sudden go's black. Sound is ok it is 100% loose contact problem. 1 please check for any connector or print for loose. 2 in signal processor ic there might be loose. remember there is no component failure.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
