ITS ALTERNATIVELY SHOWING ERROR 4 AND 1 IN LED DISPLAY. WHAT IS THE PROCEDURE FOR SOLVING THIS
Posted by mkmohan_eng on
Anonymous
  • 526 Answers
It would be nice if you said the brand and model #, I will assume its a brother. Not sure on the model.
However, the most common issue related to an error 41 is that the printhead is bad.
It will need to be replaced.
thanks
Posted on Jan 26, 2011
My Toshiba washing machine model AW-A800MBK This have 4 LED lights, Now machine running some time drain and showing LED 2,3 glowing and then machine stop, What is the problem with this machine?
Toshiba top load washers have standard error codes. Depending on the display (2 or 3 digits depending on the model) it will either show E21 (or E23) or alternate E2 and -1 (or E2 and -3). Here's a list of most Toshiba washers error codes;
E1: Water doesn't drain in time or not at all
E21: Lid open
E23: Lid not locking
E31: Load imbalance
E32: Check E1 and/or E31
E5: No water coming in
You can try resetting to factory default by following the procedure: Power OFF, then pressing and holding the Super Spin Dry button, press power ON and it should beep 3 times. E2 error code aw 8990st toshiba wash Washing Machines
Mar 13, 2018 | Washing Machines
Error 2
HI,
THe error E2-indicates no paper error
othe error codes:
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
Try resetting the printer,think this should solve your problem
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
RNJ VINODKUMAR
Oct 04, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
My printer show error e28, help solve it, please
E28 = Ink cartridge temperature rise error
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
button pressing
5) Unplug cable power.
Aug 04, 2009 | Canon Office Equipment & Supplies
ERROR CODE E-4 0. No activity on turning ON the printer
MP150/160 resetting errors: do a EEPROM reset
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD over current error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
button pressing
procedures below.
procedures below.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 24, 2009 | Canon PIXMA MP150 All-In-One InkJet...
I have refilled my ink cart. and now an error E5 is showing.
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
tonl-i-14
Apr 13, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Printer problem
Reset procedure:
Service mode operation procedures :
orange and green, starting with orange.) The number of the Reset button pressing LED Function Remarks
4 times Green Waste ink counter reset See waste ink counter reset procedures below.
5 times Orange Destination setting See Destination setting procedures below.
Reset except for the followings:
- USB serial number
- Destination setting
- Waste ink counter
May 11, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon printer mp150
can you try to reset, here are the steps
Mp150
Reset Counter
Service mode operation procedures -
button pressing
procedures below.
procedures below.
Feb 08, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon Pixma MP150 Error code E 42
Had exact same problem. Scanner light should come on at power up. Found ribbon cable connecting scanner unit to base had come unplugged from socket on circuit board. The ribbon cable is one of three found near back hinge of scanner and is hidden underneath the other two. It should drape over the edge of circuit board and then plug into small recepticle on inner side of board. I plugged it in and printer works again. Hope this helps.
Nov 04, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Service Error with my cannon printer 160
TRY THIS STEPS...
Mp150 Reset Counter
button pressing
procedures below.
procedures below.
Oct 24, 2007 | Canon PIXMA MP150 All-In-One InkJet...
43 people viewed this question
Marvin
Marvin
