Polaroid Polaview 211E Multimedia Projector Logo
Question about Polaroid Polaview 211E Multimedia Projector
After about ten minutes, it overheats and the lamp shuts off.
Posted by chiefofthere on
Joseph Gallucci
    Scholar:
  • 120 Answers
Check all the fans and filters, make sure all the fans are turning properly and make sure none of the filters are plugged there is usually only 1 but there may be more.
Posted on Jan 27, 2011
My Pioneer projection TV model SD p6081-k loses
Your lamp is turning off, there is a temperature sensor who will shut down the lamp(s) if they will overheat.
Open the back vacuum all the dust and clean the fan(s)
Epson Projector, Model: EMP-X5, Epson projector shuts down after 30 minutes work
There are several things that can cause this problem, but the first thing I would check is the filter. The projector requires airflow to keep it cool. If airflow is blocked, the projector will overheat and shut down automatically.
Overheat protection tripping
Starts running and after about ten minutes trips the circuit breaker anf nthe shuts off. This is the PLM14000EH.
I have a HLN617W samsung dlp it works for about ten minutes and the picture is great but after the ten minutes the tv just shuts down what could cause this to happen
Hi:
It may be time for a new lamp if you have not changed the lamp since purchasing the unit, then it is time for a new one.
Shutting off and turn back on ever five to ten minutes
Did you replaced lamp in Hitachi 60VX500 tv in last 2-3 years?
If not then it is time to replace lamp to solve tv issue.
Let me know if you have additional question.
Thanks.
My Gateway 7510GX shuts down after ten minutes. I
i think there are two causes for this reason.1/ ur processer fan is not working properly. at that time u should get this message as thearmal heat. then ur computer shutdown. 2/ setting of power option my be fixed 10 minnutes. we should kee poweroption always never shutdown.
Sudden overheat
hi  ernie try changing the thermostate first as this can cause this  D
Optoma ep716
Go to the onscreen menu and check lamp settings. Disable auto shut-off.
Sharp Notevision XG-NV6XU
Looks like the wrong lamp was installed, or the cooling fan is not working. Careful - it may be permanently damaged, as the LCD inside can be hurt by high temperatures.
Top Polaroid Office Equipment & Supplies Experts
Steve Nordquist
Steve Nordquist
W.L.
Clive
Clive
Are you a Polaroid Office Equipment and Supply Expert? Answer questions, earn points and help others
