Casio G-Shock GW500A-1V Wrist Watch Logo
Anonymous Posted on Jan 26, 2011
How much is a new battery for a GW-500A? It is solar powered is it common for the battery to need replacement?
Anonymous
Level 3:
  • Master 6,771 Answers
  • Posted on Jan 26, 2011
Anonymous
Master
Level 3:
Answers
6771
Questions
0
Helped
1777275
Points
21413
The rechargeable batteries last one to three years and must be replaced, cost depends on make and model, so I can't give you a price, but should be easy to find out from the jewelers.
Removing metal wrist strap casio gw-3000bd
With most watches, use an Exacto knife to compress the pin to remove it. Replacing the pin is more difficult.
My Casio Gw-300 G- Shock watch face intermittently goes blank altogether. Immediately prior, the solar battery shows a full charge, (in addition, the back-light battery is less than a year old). When the...
From your description the solar cell charges the battery and keeps it topped up. I think the rechargeable battery is the problem because when the screen goes blank the battery level drops to low and the LCD blanks out which would explain the intermittent operation of the watch. I think it is worth getting it checked out with an estimate.
I have a gw-500a and the battery got replaced with a brand new one, but my watch still says charge and it won't let me change the mode or anything. The time is on the screen though. Please help
You have to reset this watch after battery replacement. Using tweezers or something similar you have to touch the AC & - contact on back of watch, for 2 seconds. Hope this helps.
3helpful
I have a Casio Shock Risist watch (GW-500A) that says "charge" on the display, that is all it shows. Does it need a new battery or what?
this watch requires no battery. It uses solar cells. my watch did this as well. to make the watch functional again my advice is to not wear the watch for one day and place it near a window that gets a lot of sun.
Need to replace casio atomic solar watch 2608 gw-300
Check out this YouTube video which walks you through the battery change process:
http://www.youtube.com/watch?v=ogCz2vjUKVg
Top Casio Watches Experts
k24674
Robert
ZJ Limited
ZJ Limited
Are you a Casio Watch Expert? Answer questions, earn points and help others
