Question about DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine
DeLonghi Esclusivo Magnifica grinder cogs have stopped spinning while the hub turns, thus no grinding is done! Help
Posted by gduncomb on
mark warfield
  • 452 Answers
U need it all set back up///needs grinder tanken out . if lugs are broken u need to put new grinder in....
Posted on Feb 28, 2011
  • jen_49 Sep 06, 2011
    how do you take the grinder out
Poured water in my delonghi magnifica beans hopper.
Have you tried grinding a few cups of uncooked rice through the mechanism to see if this will shift the dried on coffee grounds. It worked for a friend of mine after several attempts
Dec 31, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Stopped grinding beans, no action when I press the grinding button
Hi, your grinder needs to be replaced. Its a pretty easy job. The grinder comes as a full assembly, new cutters and all. dazza
Oct 13, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
The grinder on my DeLonghi seems to be stuck. It makes only a noise but not s bean is ground and one can hear it is not turning. Any solutions? Thank you
Likely a foreign object is blocking up the grinder. Remove all beans and run at coarsest grind to try to clear it, chase it through with more beans if necessary. If this does not clear it then the top burr of the grinder assembly can be removed after disassembling the machine. Mark the grinder coarseness cogs before moving them to assist reassembly. Moderately difficult procedure.
Aug 11, 2011 | DeLonghi Magnifica 3300 Espresso Machine
My grinder spins but no coffee powder coming out. I tried to open the top cap to vacuum out the beans and cleaned it with a brush and so, but still no coffee powder coming out from the grinder. What can i...
This happened to me when I first used my machine and I had accidentally pressed the button for ground coffee (the button on the front with the coffee spoon pictured) - when I turned this button off it worked perfectly and has done for over a year now.
Mar 28, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Hi I have the Delonghi Magnifica ESAM4200 which I haven't used for a couple months, went to use it tonight and the grinder worked, the lights came on in the order they generally would, but I dont seem to...
hi turn unit on as normal ..when its ready to wash through turn the steam knob fully open that will sort it ... then shut it off again. job done ,,,,run open for about 15 sec.. any repairs needed we do a postal service .
Feb 28, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Can you grind hazelnuts with the coffee in our 3000 magnifica
I would not do this as hazelnuts are oily and will probably gum up the grinder.
What you could do is but a few ground hazelnuts in the pre-gound chute at same time coffee beans are grinding. These will go into brewer unit at same time as coffee.
Please dont forget to vote this answer was helpful
Many thanks
Feb 14, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Attemps to gind but no beans seem to get through Then the display indicates 'add beans' although it is full
Machine thinks there are no beans because it is not grinding. Most likely the grinder is blocked. The common causes are a small foreign object, a stale hard bean and moisture (either from water spillage or moist beans). The first thing you should do is vacuum ALL the beans out, set it to the coarsest grind setting and run the grinder a few times ( with no beans). Then put a small amount of fresh beans (make sure they are dry and not from fridge or freezer) in and try again. Give it a few goes. If it still wont grind have a good look down there, if it looks wet let it dry out for a while and try again. If none of thes easy tips help you will have to remove the top grinder burr and clean both burrs. Good luck.
Dec 14, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
The machine makes a very loud noise when grinding the coffee beans. * Magnifica Espresson Machine *
Even a properly operating super automatic DeLonghi espresso machine makes enough coffee grinder noise to scare your pets and wake you next door neighbors. It's LOUD, no doubt about it. Only if your grinder makes more noise than that do you have a problem.
Jun 23, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Coffee machine Delonghi Magnifica grinding function not working
There are two reasons for this usually. Either the grinder is jammed or the grinding wheel or wheels have broken. Your machine needs to go to a repair shop to be looked at.
Jan 13, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
DeLonghi Esclusivo Magnifica ESAM3300 Espresso Machine Logo
1,299 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
