Question about HP LaserJet 3055 All-In-One Printer
JUST CHANGED TONER CARTRIDGE AND NOW THE PRINTER IS PRINTING BLURRY. HOW DO I FIX THIS
Posted by gbenere on
Seeker5211
    Genius:
  • 1,089 Answers
Put back the original cartridge and print a page. If it is not blurry, you bought a bad cartridge. Take it back for exchange.
Posted on Jan 26, 2011
HP 425N PRINTER NOT PRINTING CLEARLY
Sounds like a bad toner cartridge or a bad fuser. Try a different cartridge and also try running a cleaning page.
Sep 20, 2014 | HP LaserJet 4250n Printer
1815dn printing is faded
IF this is a high use printer, there are some other things that might be in need of attention. There is a corona wire, drum and drum wiper that are consumables too.
Mar 31, 2014 | Dell 1815dn All-In-One Laser Printer
Print is blurry
Remove the toner cartridge and print cartridge assembly. Slightly shake it from side to side to redistribute toner properly. Also, please check the supply level of your toner cartridge.
You might want to consider replacing the toner cartridge since you have already replace the PC unit.
Also, check the transfer roll for signs of toner buildup and contamination.
Inspect the HVPS contact (transfer roll) for contamination. Verify the high voltage cable is plugged into the LVPS/HVPS.
If all the steps mentioned above were done. I would suggest you contact Lexmark Technical Support for further assistance.
Apr 04, 2012 | Lexmark E360d Laser Printer
Mf6500 imageclass - when i make copies, i get fat blurry black blobs, which go from left to right. i have changed the toner cartridge three (3) times. is it the drum?
From my recollection the drum is a part of the toner cartridge in this printer so having changed that 3 times, it would not be at fault. I believe your machine has a worn/torn fixing film which is in the fuser assembly. That is the heated area where the paper goes through before exiting the printer. There is no quick fix other than replacement.
May 11, 2011 | Canon Office Equipment & Supplies
Printing dirty
This is caused by one of 2 things. It is either the toner cartridge or the fuser film is going bad. Your printer may be printing fuzzy, blurry, or other faint text because of dirty print heads, so try to clean them, including roller.
Apr 27, 2011 | HP LaserJet 2420 Printer
The copies look faded out as if a new toner is needed, but I just changed the image drum and the toner cartridge
It could be that the print density setting is set too low. Adjust to higher density printing.
If the ink of the toner is not well distributed, remove the cartridge toner from the printer. Shaking it to redistribute toner more evenly will help..
Reset the printer
On the printer press the menu button until you reach MAINT.
Then press the item + button until you reach DRUM CT RESET. Then press select.
That will fix it.
Thank you for using Fixya
Alp
Sep 19, 2010 | OKI B4600 Printer
Changed the drum & ink cartridge in HL-1440-ink bleeds on edge
This problem is often caused by spilled toner. Open the printer, carefully remove the cartridge, and give it a few bursts of compressed air. Often running several pages or type through will also fix this. If it persists, replace the toner cartridge.
Hope this initial info/idea helps. Let me know for any clarifications.
Jul 08, 2010 | Brother HL 1440 Laser Printer
Printer is printing entire page black
  1. clean the cartridge properly.
  2. take the waste toner from waste section
  3. change drum
  4. change chip
  5. do it this i think your probalem is solved
new problem
  • changed black cartridge but print color mixed print out
what i do? send the details to my email
May 14, 2008 | HP Color LaserJet 2600n Printer
My printer prints blurry lines!
Try this: make a copy and stop it when it reaches the cartridge ( has to have image on paper) take out paper and look at it, does it have blurry copies? if yes, then the problem is with the cartidge or (worse) the laser printing device ( expensive).
Take a chance and replace the cartridge.  if still there you need to replace the laser unit.
If it does not have blurry copies when you stop it at the drum then check the fuser unit( doubt it ) to see it it has any writing or toner on it.
Good Luck.
Oct 31, 2007 | Office Equipment & Supplies
HP LaserJet 3055 All-In-One Printer Logo
324 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
