SOURCE: samsung mp3 player crash
Hi undercover. I don't have experience of your actual model, but I've had a similar thing happen to my Inovix MP3/4 player when it crashed (also crashing my whole computer!) and went completely 'dead'. Plugging it into the USB port had no effect - no charge symbol and the computer didn't even acknowledge something was being plugged in. Basically, I kept on trying every time I was on the computer! 2 days later, I plugged it in and 'ding-dong' Windows XP recognised something was in the USB port. I then carried out a Firmware re-load using the supplied disc, and my player burst into life! Firmware crashes are pretty common with various players, I believe. Depending on how old your player is, try the manufacturer's website to see if they've updated the Firmware. Good luck.
SOURCE: Lcd screen shows white screen and black marks
you can fix the problem by having the original sansa files when you format it it deletes everything
get a friends sansa files or do this
and just because it would be a pain looking for the original files i uploaded here for people who deleted them put these files into a folder named
DATA http://www.divshare.com/download/4002990-1d7
WMDRMPD http://www.divshare.com/download/4003086-013
REFS--no files
and put them in into 1 folder named SYSTEM--make it hidden then put it on sansa
then create a music folder make it hidden
then create photo folder with thumbnail and my album folder make my album hidden
then create pictures folder make it hidden
then create playlists folder make it hidden put this file in it
http://www.divshare.com/download/4003139-94b
make a record folder with 2 folders named radio and voice
make a folder video
captilize all these except the one listed below
make a tmp folder
this should work :)
SOURCE: 8gb philips mp3 player
The license on the songs is limited, or the songs downloaded are only samples. Convert the files to mp3 format, and you will find that you no longer have a problem.
SOURCE: wont turn on
To turn the player on, not only do you have to slide the switch to the 'On' position, but you also have to hold down the 'Play' button for a few seconds. A little boy on a snowboard should fly across your screen at that point, if that was the problem. ^^
