Question about Samsung RS2534 Side by Side Refrigerator
I have a two year old samsung side by side refrigerator RSA 1DHMH. The freezer department has suddenly stopped producing ice and the temperature has risen significantly that food as now thawed. I have checked the water line and thats ok. I have reset the fridge by unplugging and resetting the thermo stats. All the indicators are reading correctly and the water is dispensing fine. The fridge is not affected. Any ideas?
Posted by petesadle510 on
D. Floyd Kolb
  • Samsung Master
  • 43,501 Answers
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Jan 30, 2011
Samsung refrigerator RS264absh Freezer not cooling
I would check three things in your freezer seeing how your getting ice the t-stat ,the heater,and the fan these are the first things you check with ice build in freezer your freezer is what actually produces the cold the air from the freezer travels through small vents into your refrigerator sounds like a definite defrost probelm in your freezer
Apr 28, 2010 | Refrigerators
Fridge temperature has suddenly dropped to 15
Check the door gaskets, condenser fan, refrigerator fan and the freezer fan. That should narrow down the problem.
Dec 03, 2009 | GE Monogram ZISx420DR 42-inch Side by Side...
RS21FCNS - No water
It could be the water soleniod screen is clogged or if you have a filter clogged. Take the water line loose and check the screen first.
Sep 25, 2008 | Refrigerators
Amana ARB9058CS Bottom Freezer - tremendous frost build-up in freezer on left side near ice maker at top of drawer
  1. I am not expert but this exact same thing happened to me - same model of fridge. The line which brings water in is frozen. I don't know how to solve it permanently, but if you take out the two produce drawers you can see where the water comes through. Put a hair dryer blowing on it for a few minutes and it will get it going again.
Aug 17, 2008 | Amana ARB9058CS Bottom Freezer...
Refrigerator not cooling but freezer is
Something has stopped the cold air being ducted from freezer side to refrigerator side of things. Possibly duct blocked due to ice build up, evaporator not self defrosting etc. Turn unit off for a few days till it melts and then turn back on. If it was because a door has been left slightly open you will be ok. If for any other reason you will want to have it serviced in the next week or so.
Mar 17, 2008 | Maytag MZD2766GES Side by Side...
Ice maker doesn't make enough ice to supply two senior citizens. This is the 2nd refrigerator we have had installed this month. What can we do to increase the amount of ice it puts out. The ice bin has...
Found in the FAQ section on Samsung.com:
Samsung refrigerator freezers produce about 120 cubes per day, which is in line with most manufacturer specifications.
Empty the ice tray and let the unit run for 24 hours.
If fewer than 50 cubes are produced during the 24-hour test, then your refrigerator requires service. Please contact Samsung Service at 1-800-SAMSUNG to schedule a service appointment.
If your freezer is producing 50 to 90 cubes per day, try the following:
  • Set the freezer temperature display to a lower setting. Freezer temperature must be 5 degrees Fahrenheit or less for the ice maker to work properly.
  • Make sure that the water valve on the refrigerator water supply line is completely open. You can find the water valve where the refrigerator water supply line taps into your house water line.
  • If you have a water filter in your refrigerator, change the filter cartridge. For instructions, see your Users Manual.
If you want your freezer to produce more than 120 ice cubes in a day, try the following:
  • An ice maker typically makes 1 tray of ice every 90 minutes. To shorten the amount of time the freezer takes to produce a tray of ice, set the freezer temperature display to a lower setting.
  • If your refrigerator has a Power Freeze function, press the Power Freeze button to speed up the ice making process. In the Power Freeze mode, both the compressor and the freezer fan run for 10 hours continuously. The ice making interval is reduced from 90 minutes to 55 minutes. If the ice bucket fills in less than 10 hours, Power Freeze stops automatically.
NOTE: If you have just installed your refrigerator, it will take 6 to 12 hours for the refrigerator to produce ice.
You should throw away the first three batches of ice cubes that the ice maker produces (approximately 30 cubes) to ensure the ice maker is making ice from clean water.
Feb 06, 2008 | Samsung RM255LASH Side by Side...
SAMSUNG SIDE BY SIDE FRIDGE FREEZER
these appliances are a pain in the butt. fault with water dispensor is oprob that the water bottle at bottom of fridge is frozen. rise in temp is prob that defrost not taking place. not a diy unless you are experienced
Mar 14, 2007 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2534 Side by Side Refrigerator Logo
107 people viewed this question
Top Samsung Refrigerators Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
