Question about Maytag Washing Machines
Maytag P MAV6057AWW Even though the machine is level when it spins causing the floor to vibrate. The tub seems to move more than it normal would when force is applied. Thought about the damper pads, husband thinks the motor bearings?????????????
Posted by deananna on
john_cross
    Brigadier General:
  • 6,277 Answers
Hi from retired Englishman in France,
I am presuming, rightly or wrongly, that this is a front loader? I'm afraid I cannot tell from the reference.
If you are sure 1) that the machine is definitely balanced/level and that the 4 feet are equally firm on the floor and 2) the tub CAN be moved more easily than it should then it could be the dampers/shock absorbers. The bearings I would think would let you know that it/they are worn by the noise. I wouldn't expect them to go quietly!
Questions to ask are how old/used is it and has it been subjected to excessive unbalancing previously that could cause a damper to fail?
If your husband is confident and it IS a front loader have him take the back off WITH POWER OFF and visually check the damper(s). That should lead you in the right direction. Hope this helps but it is more difficult at a distance with this type of symptom.
John C
Posted on Jan 25, 2011
Washer began vibrating across floor while spinning and was found with door open. How do I get the door to close?
Seems your washer is not level with the floor . Use a leveller to check if your washer is at level to the groud . Try moving ur washer to level ground or by adding some stuff like card board etv to level the washer . If issue still persists even if its already levelled there may b an imbalace in your spinning wheel inside the washer which causes a load imbalance so see a repairman
May 30, 2018 | Washing Machines
Maytag Washing Machine Out of Balance Even When Empty
the machine is not level... put a level across front back sides to check adjust legs leveling bolts as needed.... also is the machine installed on a carpet floor??? if yes put a sheet of plywood under machine so it wont "bounce" on floor.
May 15, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
Spin cycle massive vibration everytime. Size of load doesn't matter?
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 14, 2010 | Maytag Neptune MAH5500B Front Load Washer
4 month old washer is so loud it sounds like someone dropping a trash can to the pavement from 5 feet high
Check to make sure it's level. Number one cause of vibration is not being level. Number two cause is soft floor and what I call "Sympathetic vibration" where the floor shakes a bit and it seems like it's in time with the vibration on the washer. It then magnifies the vibration and makes it worse.
If it's level and on a solid floor, you need to get it serviced under warrenty.
Feb 22, 2010 | GE WSXH208A Front Load Washer
Maytag walking
Hello. I have a few ideas for you.
1. Tilt the machine forward so the back feet are 3 to 4 inches (7.5 to 10 cm) off the ground, then set it back down. The back feet usually are self-leveling--just raising and lowering the machine like this will cause the feet to re-level themselves.
2. Place your level perpendicular to the front of the machine and check to see if the washer is level in this direction. If it is off, readjust each front foot by the same number of turns until you reach level.
3. Go to the carpet store and buy a remnamt which is the size of the washing machine lengthxwidth. Place this under the machine with the four legs all resting on the carpet.
Regards, Joe
PS please rate my answer. thank you.
Dec 20, 2009 | Maytag MAT13MN Top Load Washer
The inner washing machine tub seems to vibrate in spin cycle only.
you could have a bad balance ring or if the machine is on a floor that is not very sturdy it could cause the machine to vibrate or "walk". if the tub is loose it may need to be tightened which usually isnt the case. most vibration i notice is from the floor or the machine not being level.
Sep 17, 2009 | Kenmore 98702 Stacked Washer/Dryer
Shaking in spin cycle and tub moves too easily in washing machine
the tension springs on the tub mite have came loose during moving
Jul 01, 2009 | Washing Machines
Maytag washer bangs during spin cycle
chances are you had a blockage in the pump and it tried to spin with the water still in the drum. check the bottom hose and filter for blockages so it does not occur again.
Jan 19, 2008 | Washing Machines
Washing Machines Logo
65 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
