Question about Philips 42PFL5332D 42 in. LCD Television
Appearing on one channel in the bottom right hand corner is a correction symbol in red (a tick mark) directly underneath that are two semi circles (resembling an ear). I cannot get rid of this and it only appears on one channel. Not sure how this suddenly appeared I must have accidentially hit something on the remote but nothing I have done removes it, including resetting the factory settings in the installation menu.
Bruce lee
    Genius:
  • 1,637 Answers
CERTIFIED TV EXPERT HERE, follow this information I provided 3 long solutions to this issue/s Solution 1 Before we start taking things apart, lets try your simple remove power plug routine and power system back up. Also, please try your unit on a few different channels to see if your problem continues on each channel. Your Main Board, Power Board, T-Control Board are suspected problems at this time. Press and hold the power button for about 15 seconds, the unit should power down by itself after you have powered it on. If it does not, then do not be concerned. Let me know if the problem continues. The first link below will bring you directly to the troubleshooting guide if you need to continue forward with the same error. Additional information http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums http://en.wikipedia.org/wiki/Capacitor_plague Parts: www.shopjimmy.com 2 Lets focus on the external portion of the TV set first (95 percent of all TV problems are related to things EXTERNAL To the tv itself) Check the physical CONNECTION of all cables by removing each wire bare or RCA and reinstalling it (Each power cable as well), once you have removed one cable, check it for fraying, and if it is already bare, splice a new fresh connection for it. 5. Check to make sure there are NO OTHER uneeded radios, system nearby. these systems, when powered on, will cause electromagnetic interference and prevent more than just severe tv interference SURGE PROTECTOR Surge protectors account for more than 75 percent of electric faults to stereo equipment. Lets start with your AC Wall outlet. It is standard in america that 220 Volts from out of these outlets. This implies that each device will be using 220 Volts (From within that grid zone). If anything including an alarm clock is plugged into any AC outlet socket in the vicinity of the stereo equipment/TV, it will cause electric outage, and prevent electronics from even turning on! Your TV needs dedicated electric power. If your TV is located in the living room then unplug everything else in the living room. Lets plug the TV set into a Dedicated socket. Check all light switches to ensure that power is on for that outlet. Check the TV cable for Fraying both on the ac wall end and where it plugs into the TV. Check all GFCI outlets to ensure that all red reset buttons are pushed in, check the circuit breakers for proper connection and they are turned on. Now, lets try the TV set without it connected to any cable services, vcr, dvd, stereo system, etc. Please respond if we have found a solution. 3 When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components. I have been working on these a long time so feel free to follow up with me
Posted on Jan 25, 2011
Hi could someone tell me what the difference between semi directional and omni directional and multi channel surround sound on a home cinema is ? K
Omni means it can receive from a full circle, semi directional means it must be pointed in the general direction of the signal in degrees of arch..
Jun 28, 2017 | The Audio Players & Recorders
Tip
How to remove a song from spotify playlist
Direct your attention to the top right hand corner of your playlist when open, click on the tree dots and click edit. Proceed to click on the red circle, delete the song and press done when complete.
on Jun 06, 2016 | Miscellaneous
There is a round black circle, bottom right corner of the screen when on
could be a burn from constant display of each channels ID
turn off from the wall
wait an hour
see if the screen settles
May 02, 2016 | Televison & Video
I have an acer aspire one, and am having issues with a 3G symbol that keeps appearing in the middle of my screen without warning. It looks like it is some kind of setting and is trying to connect to...
The thing that might be annoying you is called *Launch manager*. Well.. That's what I think. Look at the right-down corner of your screen in the Windows Taskbar, expand all Items, and search for the *launch manager* icon. Like this. Right click it, and choose *close*. Tataaa.
Dec 09, 2010 | Acer Aspire One Netbook
My symbol mc50 scanner wont turn on.battery is fully charged but screen doesnt show anything
it is possible that if you changed the battery you forfot to move the slide button next to the battery to the correct position. It often happens to me :-) Please check it, its on the right top corner of the battery, you should not see the red marking, if there is the correct position.
Nov 27, 2010 | Symbol MC50 Pocket PC
E-74 red light on bottom right corner
sounds like the red ring of death, contact xbox as they give u a 3 year warranty on this, they will pick it up and return it fixed.
Aug 07, 2009 | Microsoft Xbox 360 Console
Unable to unlock Centrex tv model CTT6809SF
Try holding down the + symbol on bottom right hand side of controller for more than 4 secs
Jan 01, 2008 | Televison & Video
Philips 42PFL5332D 42 in. LCD Television Logo
55 people viewed this question
Top Philips Televison & Video Experts
ThaMp3Doctor
ThaMp3Doctor
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
