SOURCE: new cartridge-wont pump cleaner
The cleaning fluid "pump" is actually a small Mabuchi 6V DC motor that uses two small plastic spur gears in mesh to "pump" the fluid up a tube into the cleaning reservoir. Mine has died also and I cannot find a replacement motor. The cheapest I have found the base is here: http://www.electricshaverstore.com/get_item_scc1_braun-syncro-clean-charge.htm Good luck, Lynn Livingston
SOURCE: Base floods with solution during cleaning cycle
OK, Remove shaver from cleaning base. Raise top cover as if you are going to replace the cleaning cartridge. Now, look into the cleaning cup where you put the shaver into.You will notice a small hole on the bottom left side. With a Q-tip ,clean out the beard hair from the hole.If you have a model 5301 which is located on the bottom of the base, you should be able to push the Q-tip all the way through the hole. This will allow the liquid to flow back down into the cartridge.This is whats causing the overflow.
SOURCE: Clean Cycle Never Ends
i have the same issue but the charge/clean light on the razor itself wont come on or charge at all. Braun said to send it in for repair/exchange and to find out whats wrong with it.
SOURCE: Non cleaning razor
Dear Freddofrog,
please ensure you have removed the plastic plugs from the cleaning fluid container. If you have removed these i would suggest that the fluid contaner is faulty, your place of purchase should exchange this for you with no problem.
SOURCE: I have a Braun 760 razor. The two electric
Useaa good emery paper to clean the surface of the contact, use a good contact oil to rub off the rust or dirt in the section. now repeat till it shine, do the same to the other end , Now since there is alwyas some moisture present the pins must be cleaned out after very use.
