Bosch Classixx WVF 240S Front Load Washer / Dryer Logo
Posted on Jan 25, 2011
I need to know how to best maintain my Classixx 1000. I am without a manual.
Anonymous
Level 1:
Champion:
  • Contributor 266 Answers
  • Posted on Jan 25, 2011
Anonymous
Contributor
Level 1:
Champion:
Answers
266
Questions
Helped
54326
Points
6
Run a clean cycle every month
2helpful
What is the H, D and W measurements of the Bosch Classixx 1000 washing machine?
The Dimensions are :-
1. Overall Height - 85.6 CM
2. Overall Depth - 59 CM
3. Overall Width - 59.99 CM
CM - Centimeter
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Bosch classixx 1000. Impeller loose.
You are best fitting a new pump asa temp repair impeller can be reglued but a new pump is bet fitted.
1helpful
Softener won't empty in Bosch Classixx 1000
take out the soap drawer clean in hot water inside the machine where you took the soap drawer out at the top look for the hole where the water runs out it may be blocked with mildew dettox mildew spray is very good at breaking all that down spray in leave for a while put soap draw back in and do a wash without clothing as spray contains bleach
3helpful
Classixx 6 1200 Express washing machine manual
whay may nero 9 serial number it das not working? ma old S.N invalid
Help with child lock instructions
to my knowledge there is not a child lock on this model its at the basic end of the range only upper range models have this feature.sorry.
Bosche classixx 1000
Rotate the drum by hand. If the drum spins to freely without much resistance then it is possible that the drive belt has come off. Its unusual but it can happen. Remove back panel and refit the drive belt carefully.
If the machine is older than 5 years its possible that the wash motor brushes need replacing. If this is the case then you need to call a technician to replace them.
0417362396 Melbourne Metro area
Regards Sam
15helpful
5answers
Bosch Classixx 1000 manual
usually it is the larger for the main powder the second largest for the prewash powder and the smallest (labelled with a "max line" for the fab conditioner) the calgon can go in with the main wash or be put straight in the drum.
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
