Question about Canon Office Equipment & Supplies
Printer is printing with a pink hue - Canon Office Equipment & Supplies
Posted by imacrashtest on
ikkenom
    Brigadier General:
  • 10,406 Answers
Your printer mixes the 3 colours in the tri-colour ink-cartridge to achieve each colour.
So, printing in 'PINK' suggests that one of the other 2 "primary" colours is OUT-OF-INK.
Replace the ink-cartridge.
Posted on Jan 25, 2011
I have a Dell 5100 CN Laser Printer and it just started to malfunction. I replaced all 4 toner cartridges thinking that the pink hue on each printed page was due to a faulty ink cartridge. I replaced ALL...
If this printer features drum units that are not included with the toner then I would suggest that this is a more likley cause of the problem than the toner. Take a look at the drum, if the magenta is separate you may notice that it has toner on it. If it does it is likley defective as it should be clean when removed from the printer.
Jan 06, 2015 | Dell Office Equipment & Supplies
All ink tanks have been replaced with OEM and photos are still printing with a very pink hue. What's the next step to solve this problem?
Sounds like one of your print heads might either be plugged or not working any more. Try removing the cartridges and cleaning the print heads with a Qtip (with isopropyl alcohol), or try a print head cleaning from the printer settings menu in Windows.
Mar 05, 2011 | Canon i860 InkJet Photo Printer
My printer is printing in pink color how can i change it to black
Sounds like your black cartridge is either empty or clogged. Take out the black cartridge and press the print head against a moist paper towel. You should see a nice black rectangle, if you don't you could try placing the print head on a wet paper towel for a few minutes to wick out the ink (ink may seep through the paper towel so beware what surface you do this on). If after this there is still no ink flowing, buy a new cartridge.
Dec 18, 2009 | Office Equipment & Supplies
Pixma IP5000 printing pink
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 07, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Everything's magenta!
Check in your printer driver settings "advanced" section, and see what the presets are. if the RGB or CYMK settings have a slider, see if the magenta is set at 100%. If it has a slider, try it at 90%, 80%, etc until you have a less pinkish hue. You can then create a printer profile which will work with the photo paper you are using.
Different photo papers can cause hues like this.
Also, you can remove pink any unpleasant hues with most photo image editors through color correction.
It's possible that you have a contaminated cartridge...especially if it's a refilled tri-color cartridge.
Dec 09, 2008 | Canon Office Equipment & Supplies
Epson stylus dx4050
hello, I hav Epson Stylus Dx4050, there is black ink,but the colours finished and it stopped printing, so please if you could tell me if the 4 colours must be there to print or what can I do?
Thanks very much
Jul 01, 2008 | Office Equipment & Supplies
158 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Ekse
