Question about Hobart HL600 Legacy Stand Mixer
HELLO, My name is Timothy and I got a motor repaired for the Hobart H 600 stand mixer and I need to ask one Question. What is the gear oil that this model takes as I lost some of the gear oil during teardown.
Posted by tjs_beaner on
None
    Scholar:
  • 44 Answers
Planetary takes six ounces 150 weight gear oil if completely drained (i.e. Exxon Spartan EP 150 or equivalent). Transmission uses one gallon 460 weight (yeah, 460 weight!) gear oil (Exxon Spartan EP 460 or equivalent).
Posted on Feb 03, 2011
How to invert motor turning direction?
Hobart A200 Stand Mixer
Beatriz, I looked through the entire manual, it shows no reverse option. Did you just get the mixer or did you have it repaired. It seams the mixer is either wired wrong or the gears that rotate the mixer were not assembled correctly.
Check the attached link,manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
https://my.hobartcorp.com/kroger/TechnicalServiceManuals/A200%20Technical%20Manual.pdf
A200 Hobart Service
Apr 06, 2016 | Hobart A200 Stand Mixer
I have a Hobart P660 stand mixer. It turns on for a moment then trips the breaker. Would this be a "relay" or "switch" problem?
Hello Pizzaangel,
It sounds like you are having a problem with you Hobart P660, everytime you run it trips the breaker. Sounds like the switch is shorting out. You need to replace the switch and that should solve the problem that you are having.
Feb 15, 2011 | Hobart P660 Stand Mixer
Hobart Mixer A200 buzzing. The motor not moving
Have you try to run the motor without engaing of worm gears? The worm gear 15T assembly need to remove in order for motor to run freely. check worm gear attach to motor shaft for any damaging.
Mar 24, 2010 | Hobart A200 Stand Mixer
How do you change the oil in a hobart h 600-dt dough mixer & what type of oil do you use ?
there is an oil case drain pulg under the top by the clutch, you can drain the motor housing through there, \
i have used 5w30 in a pinch
but it would be better if you ordered hobart oil from the website
its cheap but very very good
Oct 15, 2009 | Hobart H600 Stand Mixer
My Hobart D300 mixer appears to be leaking oil/grease
Hi,I'm a hobart tech and repair these mixer's often.If you see oil in the drip cup then the center shaft seal in the transmission is worn.If there is oil near the transformer then the motor shaft seal is also bad.Hobart doesnt release their service manuals to the public but if you go to their site www.hobartcorp.com you can register for free and get a parts manual thats helpful.If you need help with the repair let me know,i can step you through it.
Mar 17, 2009 | Hobart D300 Stand Mixer
Oil change for hobart h-600 mixer
Needed to know which part to open up to add or change oil on Hobart Mixer h-600
Mar 05, 2009 | Hobart H600 Stand Mixer
Problem with Hobart D300 Mixer
Sounds to me like the shifting yokes are locked up,or a broken shaft.Is there any noise?
Dec 11, 2008 | Hobart D300 Stand Mixer
Manual for a Hobart H600, please. M Martinello 2347 Pillette Windsor, ON N8T 1P7 519-566-6677
Hello, i´m in mexico, i have a h 600 mixer from hobart. I need to know what kind of lubricant need for gear box and planetary system
Jun 28, 2008 | Hobart HL600 Legacy Stand Mixer
Hobart HL600 Legacy Stand Mixer Logo
655 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
