Question about Toshiba 32AF41 32" TV
The screen went from color to all blue. Is it a tube?
Posted by vieta66 on
Chris Ramirez
    Scholar:
  • 145 Answers
Hello there,
That sounds like the TV went to a different input best thing to do here is use the input key on the remote control, if you do not know what input the TV needs to be set too check the back if all the Connections are going to AV1 then you know the input needs to be on AV1 , if you need me to find the input for you i would need more information .
Thank you don't forget to Rate
Posted on Jan 25, 2011
Tv is yellow orange color what is problem
The model indicated does not have a "bulb" as it uses 3 picture tubes.
Examine the picture with color set at zero---stand back and look= if the screen has a mostly yellow (all or part of the screen) you have bad Glycol in the blue picture tube(if need explanation ask) and a look in the lens of the Blue tube will confirm this.
If able with back off and a small mirror look in each lens--red picture, green picture and blue picture.
If the Blue looks like a floodlight with little or no image--bad glycol in that tube.
Jun 16, 2012 | Samsung HCN5527W 55" Rear Projection...
THE COLOR WENT OUT ALL OF A SUDDEN
If the model listed here is correct--tell me if different-- it is a problem related to the picture tubes this model uses.
Apr 28, 2012 | JVC AV48P776 48" CRT TV
Have sharp quos 52" screen went pink. Can still
Hi, My guess is your daughter messed it up. Go to menu and color and reset to default should fix it.
You may have to adjust color for your best viewing. Good luck.
Sep 27, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
The color was off on the tv i took the bottom back off and there was a box with three screws on top and three screws on bottom that adjusted the colors when i turned the top left screw a little the three...
turn the center dial ( for green) down slightly then turn the other two the red and the blue up slightly to get the best screen without a dominate color screen.
Sep 02, 2011 | Philips 50P8341 50" Rear Projection...
My screen has little dots appearing sometimes red sometimes blues behind the picture i just replaced the lamp bulb as i thought it would cure the problem
the projection tube needs to be adjust for color alignment, each tube (red, green, blue) must be aligned so you there would be no color smear appear on screen. if it is aligned try to set up the color balance, hue etc.
Feb 06, 2011 | Samsung Televison & Video
The screen is all blue
back of the screen control for the blue tube
May 27, 2010 | Sony KP-51WS500 51" Rear Projection...
Color is bluing (blue bleeding thru)
you can remove front speaker cover,then remove screws from board,you will see 6 controls,3 are focas(all in a row)3 are screen controls.sets are for red green and blue,blue should be to the rite,turn blue controls until picture gets better.they are labeled screen and focas
Sep 24, 2009 | Sony KP-57WS500 57" Rear Projection...
Seeing red !
I had a television that went to a bright shade of blue.A friends neighbor worked for sony television plant where the new tubes came down the assembly line.His job was to make sure tubes were working fine,if one color was dominant then his job was to smack the front center of the tube with a rubber mallot to fix the problem.He suggested i try that with my tube while the set was on.It worked and solved my blue problem.Apparently he explained,the gun connections in the tube came loose and to fix it was to smack it this caused the connection to reweld itself.For you I would use the palm of an open hand and smack the tube dead center with a good hard smack.Dont be afraid of breaking the glass because its very thick and strong.Give this a try.Hope it helps.Good luck!
Oct 31, 2008 | RCA F25442 25" TV
TV colors are wrong
Hi,your problem is not with the tube but with the degausing circuit,a very easy repair which should not cost to much,a small componant called a possister in the primary power supply,a 5 min job for a competant tv engineer
Apr 21, 2008 | Beko 324250WN 28" TV
Toshiba 32AF41 32" TV Logo
27 people viewed this question
Top Toshiba Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
