Question about Konica Minolta bizhub 350 All-In-One Laser Printer
It shows 5351error code - Konica Minolta bizhub 350 All-In-One Laser Printer
Posted by kjrmichael on
taminol
    Sniper:
  • 62 Answers
Hi kjmichael,
Other than trying to reset the code by opening/closing front door or switching it on/off it'll probably need a technician to look at it. The C5351 code refers to the power supply cooling fan motor not working correctly.
Good luck
Regards
m-press.biz
Posted on Feb 25, 2011
Wme8227s. What does code E18 indicate?
Beko Washing Machine ' WMA Series ' Error Codes
www.ukwhitegoods.co.uk/.../fault-codes/...fault-codes/3623-beko-wma-...
Feb 6, 2013 - ... Fault Codes. Beko WMA Washing Machines With Display ... BekoWMA Series Washing Machine Fault Codes. These fault codes are ... E18 ...
UK Whitegoods • View topic - Beko WME7247W showing error code e18 ...
www.ukwhitegoods.co.uk/.../washing-machine.../beko-wme7247w-show...
Jun 19, 2011 - Hi, does anyone know what error code e18 is on a beko wme7247wwashing machine? thanks. User avatar louisebaxter: Whitegoods Newbie Beko wme7247w dc module burnt out
Apr 27, 2014
Bosch WAS24460GB showing error F:57
Sep 28, 2013
beko washer error code
Aug 18, 2012
Samsung B1415J showing error code EA ...
Jan 9, 2012
More results from www.ukwhitegoods.co.uk
Oct 30, 2015 | Beko Washing Machines
I have a p0530 code showing
looking at it as a generic code most models show it as a ac pressure code check your a/c charge if ok check the pressure switch
Aug 23, 2012 | Cars & Trucks
Master reset code for nokia 1202-2 IMEI # 358016/03/449348/0 CODE:0562271
Nokia Mobile Sets Secret Codes
Mobile Set: All Nokia Mobile Sets
Use For: Default Security Code.
Code: 12345
Mobile Set: Nokia Mobiles
Use For: Turn On Enhanced Full Rate Codec.
Code: *3370#
Use For: Turn Off Enhanced Full Rate Codec.
Code: *#3370#
Use For: Turn On Half Rate Codec.
Code: *4720#
Use For: Turn Off Half Rate Codec.
Code: *#4720#
Use For: Show Software Version.
Code: *#0000#
Use For: Also For Show Software Version.
Code: *#9999#
Use For: Show IMEI (International Mobile Equipment Identity).
Code: *#06#
Use For: Show Lock Status of Your Nokia Mobile Set.
Code: #pw+1234567890+1#
Use For: Show Lock Status of Your SIM.
Code: #pw+1234567890+4#
Use For: Show Security Code of Your Mobile Phone.
Code: *#2640#
Use For: Reset Game Score And Timer.
Code: *#73#
Samsung Mobile Sets Secret Codes
Mobile Set: All Samsung Mobile Sets
Code: *#06*
Mobile Set: Samsung 811
Use For: Unlock code / Change roaming code / ID.
Code: 47*869#08#9
Mobile Set: SGH-600 , SGH-2100
Code: *#9999#
Use For: Show Software Version (instructions).
Code: *#0837#
Use For: Show Serial Parameters.
Code: *#0001#
Use For: Activates the smiley when charging.
Code: *#9125#
Use For: Battery status (capacity, voltage, temperature).
Code: *#9998*228#
Use For: Program status.
Code: *#9998*246#
Use For: Change Alarm Buzzer Frequency.
Code: *#9998*289#
Use For: Debug screens.
Code: *#9998*324#
Use For: Watchdog.
Code: *#9998*364#
Use For: EEPROM Error Stack - Use side keys.
Code: *#9998*377#
Use For: Trace Watchdog.
Code: *#9998*427#
Use For: Change LCD contrast - Only with version G60RL01W.
Code: *#9998*523#
Use For: Memory status.
Code: *#9998*636#
Use For: Jig detect.
Code: *#9998*544#
Use For: SIM File Size.
Code: *#9998*746#
Use For: SIM Service Table.
Code: *#9998*77
Jun 03, 2012 | Nokia Cell Phones
Unlock code motorola c123
hey there, ull need to ring your network operator and ask for the ''unlocking code'',then take out your sim and type your unlocking code,this is how to enter it
a. Push #
b. Push * 3 times in a second. (p will show)
c. Push * 4 times in a second.(w will show)
d. Push * 2 times in a second(+ will show)
e. Enter the code from below.
f. Push * 2 times in a second.(+ will show)
g. Enter the code number
h.Push #
PS:ull need to have your IMEI code ready when you ring them up,to ge the code on screen press *#06#...rate me please :)
Feb 02, 2011 | Motorola Cell Phones
Changing the alarm code on the gaurdtec 500 series alarm
For a guardtec 593
Programming User Codes
(Master code only)
system.
1) With the display showing ' Un ' enter a Master code
2) The display will show ' SE '
3) Press NO five times, the display will show ' Uc ' (flashing).
4) Press YES, the display will show ' U- '
5) Enter the User number you wish to program (1 to 7) followed by YES
6) The display will show ' Co ' Enter the required code (4, 5 or 6 digits) followed
by YES. (Entering 000000 will delete an existing code).
7) The display will show ' t- ' enter the code type from the following list
1 = Set Only 2 = Main User 3 = User 4 = Master followed
by YES. A full description of code types is given on page 3.
8) The display will show ' Uc ' (flashing)
If you wish to program other User codes return to step 4
Or
To return to the Unset condition press 0
this is for the led version.
Aug 27, 2010 | House Brand Intrud Alert House Home Alarm...
Nokia n70 lock code problem..shows code error
when i put the lock code (12345) in phone.than it always shows that CODE ERROR every time.
May 18, 2010 | Nokia N70 Cellular Phone
How to unlock Nokia 6300 phone
Try code number 7 first. If it does'nt work, try code 1. Different codes work on different phones. Remember that you only have 5 tries.
To enter the code:
1. Push #
2. Push * 3 times in one second. (p will show)
3. Push * 4 times in one second.(w will show)
4. Push * 2 times in one second(+ will show)
5. Enter the code from below.
6. Push * 2 times in one second.(+ will show)
7. Enter the code number
8.Push #
Now a message like "Sim restriction off" should be displayed. That means your phone is now unlocked.
Your code's are:
#pw+228875557620475+1#
#pw+436867161410263+2#
#pw+494327720215623+3#
#pw+315916340311414+4#
#pw+183024315162023+5#
#pw+947802170570602+6#
#pw+493267323124160+7# <<
Feb 12, 2009 | Nokia 6300 Cellular Phone
Nokia 6233
You should use code number 7. If it does not work, try code 1. Different codes work on different phones. Remember that you only have 5 tries, after that you have to go to a repair shop.
To enter the code:
1. Push #
8.Push #
Your code's are:
#pw+434257063264651+1#
#pw+449037370732335+2#
#pw+892411220036617+3#
#pw+025903455301702+4#
#pw+846551371427355+5#
#pw+129954654711654+6#
#pw+336916660471213+7#
Now a message like "Sim restriction off" should be displayed. That means your phone is now unlocked. Check this after each code you try.
Feb 17, 2008 | Nokia 6233 Cellular Phone
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
581 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
