Question about Panasonic PT-47WX42 47" Rear Projection Television
Panasonic PT-47WX42 TV. Picture looks like convergence is out. I also see a Distorted picture like a Filter Capacitor has also gone out. SD Tech said he was familiar with this
  • daci426 Jan 25, 2011
    I'm looking for SD Tech. I believe there is more wrong with this system then just the convergence modules.
    Genius:
  • 1,126 Answers
It is the the convergence IC that need to be change on the convergence board, and also check for defective electrolytic caps and low ohm resisters that have changed in values too. You can also buy a new convergence module and replace the one that is in it. The have it repair you are looking at around 400.
Posted on Jan 25, 2011
  • Panasonic Master
  • 11,800 Answers
You need this
http://www.tvrepairkits.com/xcart/product.php?productid=21377&cat=0&page=1
I have a Panasonic PT-47WX42 .. porew light flashes 3 times the stops,, then repeats..if I unplug the power cord then turn on the tv. it warmsup the picture comes on for maybe 3 sec then hear a click just...
The 3 blinks is indicating the set has shut down due to the convergence circuits. You can get the convergence repair kit for your model from www.tvrepairworld.com the kit contains the parts and the CD with repair instructions.
Jul 28, 2011 | Panasonic PT-47WX42 47" Rear Projection...
The colors on my tv doesn't line up right. It has a 3D look and i tried to converge it. It will not let me do it. Its a panasonic HDTV PT-47WX42, PT-47WX52, PT-53WX42, PT-53WX52, PT-56WX42, PT-56WX52
set uses two of the STK-392-110 chips for convergence.
Both will have to be replaced.
I have start to finish step by step instructions for this repair based on me doing it in hundreds of these sets.
If you want the instructions, do you have a email?
SD TECH
Jan 15, 2011 | Panasonic PT-47WX42 47" Rear Projection...
Colors are not lined up and i can see two of everything
This tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look like.The tv 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Oct 21, 2010 | Panasonic PT-47WX42 47" Rear Projection...
Mirror or Misconvergance?
These sets have several common problems which are listed below.
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 03, 2010 | Panasonic PT-47WX42 47" Rear Projection...
The picture is wavy or gone still have sound
Projection TV sets have two very common problems listed below.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 24, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Green Convergence vertical line appears to be distorted and not streight
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Jan 15, 2010 | Panasonic PT-47WX42 47" Rear Projection...
Picture suddenly distorted, green and violet lines
It is convergence out ICs failure problem and you need to replace two ICs in convergence board/ section in TV.
If you are not familiar with TV repair then call qualified TV tech to fix it.
Apr 15, 2009 | Panasonic PT-47WX49 47" Rear Projection...
I have a Panasonic HDTV Projection PT-47WX42 with double imaging.
*Screen Looks 3-D
*Colors wont align
Nov 17, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Double image on screen
Projection sets have two very common problems.
The first common problem is convergence
*Screen Looks 3-D
*Colors wont align
Nov 09, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Picture doesn't work..Panasonic 47 inch TV PT-47WX42
Dood, if you really needed a new mother board for your TV the biggest problem on your hands would be finding the replacement.  The motherboard is so easy to remove it would make you laugh.  I think it has four clip bridges and four of five screws.  You seperate the clip bridges, take the screws off and maybe take a picture of the cables so you remember where to plug them in and you're done.  Like I said, take a snap shot so you dont forget where to put your cables back in.
Oct 14, 2007 | Panasonic PT-47WX42 47" Rear Projection...
Panasonic PT-47WX42 47" Rear Projection Television Logo
49 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
