Precor EFX 546i Elliptical Version 4 Logo
Posted on Jan 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Display message reads - "key depressed"
Sportsmith LLC
Level 3:
  • Precor Master 920 Answers
  • Posted on May 15, 2014
Sportsmith LLC
Precor Master
Level 3:
Answers
920
Questions
0
Helped
514837
Points
111994
Precor Error 05, Key Depressed at Power Up Probable Cause 1. A key is permanently depressed on the display.
2. An interface chip (IC) has failed in the upper PCA's keypad.
3. Liquid (cleaning solution or sweat) may be on the surface of a touch sensitive display.
Corrective Action
  1. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 is eliminated, the keypad is the cause and should be replaced.
  2. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 still appears, the upper PCA* is the cause and should be replaced. *Upper PCA's most commonly do not come with software. Remove the software (chip) from the existing upper PCA prior to replacement and install into the new upper PCA.
  3. Wipe away all liquid from the touch sensitive display. Reset power to the unit. If the Error 05 is eliminated, the liquid was the cause.
Precor Error Code 05
1helpful
"stuck key" message on efx 546i, will not engage, already replaced batttery
Corrective Action
tip
Ink System Failure Fix for Some HP Printers
<span><span>Hewlett Packard Ink System Failure Error Fix (tested C6180) </span></span> <ol> <li><span><span>Press and hold the "*" key. </span></span></li> <li><span><span>Press the "#" key and release both keys. Display should say "Enter Special Key Combo" </span></span></li> <li><span><span>Press and release in sequence the "1", "2" and "3" buttons. screen says "support" R0631M </span></span></li> <li><span><span>Press and release the right arrow button until the display says "System Configuration Menu". </span></span></li> <li><span><span>Press and release the "OK" button.</span></span></li> <li><span><span>Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status", </span></span></li> <li><span><span>Press and release the "OK" button. </span></span></li> <li><span><span>Display should say "Hardware failure status: Clear. Press OK to clear". </span></span></li> <li><span><span>Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue". </span></span></li> <li><span><span>Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. </span></span></li> <li><span><span>Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.</span></span></li> <li><span><span>Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer </span></span></li> <li><span><span>Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. </span></span></li></ol><span><span>I hope this helps</span></span> <span><span><br /></span></span> <span><span>Regards GM</span></span>
tip
HP Photosmart C6180 Ink System Failure
<br /> Hi,<br /> <br /> <br /> Please perform the following steps and let me know the message that will be displayed on the printer.<br /> Press and hold the "*" key. <br /> Press the "#" key and release both keys. <br /> Display should say "Enter Special Key Combo" <br /> Press and release in sequence the "1", "2" and "3" buttons.<br /> Press and release the right arrow button until the display says "System Configuration Menu".<br /> Press and release the "OK" button.<br /> Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status",<br /> Press and release the "OK" button.<br /> Display should say "Hardware failure status: Clear. Press OK to clear".<br /> Press and release the "OK" Button. Message changes to "Hardware failure status Press Cancel to continue".<br /> Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.<br /> Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.<br /> Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer<br /> Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.<br /> <br /> If I could be of further assistance, let me know. <br /> Thanks,<br /> <br /> LETMEFIXIT
I am getting a reading on the screen of "er 05" i
Corrective Action
Stairmaster 3800 Display screen reads "CONFIG
Display reads CONFIG RQRD or NTM CONFIG RQD on Stairmaster Equipment Probable Cause The message CONFIG RQRD or NTM CONFIG RQD appears when the console needs to be configured for the machine type it is installed. This message is common when the console has been replaced or if the settings have been changed. Message is commonly seen on various Stairmaster equipment such as bike models 3000CE, 3300CE, 3400CE, 3600RC, 3800RC and 3900RC; stepper models 4400PT, 4600PT, 4400CL, 4600CL and SC916; stepmill models 7000PT and SM916; elliptical model ClubStride 5100.
Corrective Action
  • Make sure the unit is in an "idle" state. "Idle" state means the console is not displaying an error or any message that requires data input. The display should basically be freshly powered up, scrolling the EKG or welcome message
  • Configure the console for the proper machine type by pressing Level UP, 80, ENTER
  • Using the Level UP or Level DOWN keys, scroll through to the proper machine type (Bike, Elliptical, Stairclimber or Stepmill)
  • Once the proper machine type is shown on the display select the machine type by pressing ENTER
  • This completes the steps necessary when your Stairmaster display reads CONFIG RQRD or NTM CONFIG RQD
Stairmaster Console Message CONFIG RQRD or NTM CONFIG RQD
The voicemail light stays on and message on phone reads "Message for you" on display. Voicemail has been opened and says that you have no messages.
More than likely a co-worker used the "send message" feature on thier set. Under where it says "message for you" one of the soft keys should say MSG. Press the MSG soft key then the ERASE soft key. That will return your screen to normal.
1helpful
2answers
What button sequence to I press on the vic to get the cpu codes for the check engine light?
Reading & Clearing Codes READING CODES (EXCEPT CADILLAC) Fig. 4: Example of a code 12 displayed on the check engine lamp 79222g25.gif
Since the inception of electronic engine management systems on General Motors vehicles, there has been a variety of connectors provided to the technician for retrieving Diagnostic Trouble Codes (DTC)s. Additionally, there have been a number of different names given to these connectors over the years; Assembly Line Communication Link (ALCL), Assembly Line Diagnostic Link (ALDL), Data Link Connector (DLC). Actually when the system was initially introduced to the 49 states in 1979, early 1980, there was no connector used at all. On these early vehicles there was a green spade terminal taped to the ECM harness and connected to the diagnostic enable line at the computer. When this terminal was grounded with the key ON, the system would flash any stored diagnostic trouble codes. The introduction of the ALOL was found to be a much more convenient way of retrieving fault codes. This connector was located underneath the instrument panel on most GM vehicles, however on some models it will not be found there. On early Corvettes the ALOL is located underneath the ashtray, it can be found in the glove compartment of some early FWD Oldsmobiles, and between the seats in the Pontiac Fiero. The connector was first introduced as a square connector with four terminals, then progressed to a flat five terminal connector, and finally to what is still used in 1993, a 12 terminal double row connector. To access stored Diagnostic Trouble Codes (DTC) from the square connector, turn the ignition ON and identify the diagnostic enable terminal (usually a white wire with a black tracer) and ground it. The flat five terminal connector is identified from left to right as A, B, C, D, and E. There is a space between terminal D and E which permits a spade to be inserted for the purposes of diagnostics when the ignition key is ON. On this connector terminal D is the diagnostic enable line, and E is a ground. The 12 terminal double row connector has been continually expanded through the years as vehicles acquired more on-board electronic systems such as Anti-lock Brakes. Despite this the terminals used for engine code retrieval have remained the same. The 12 terminal connector is identified from right-to-left on the top row A-F, and on the bottom row from left-to-right, G-L. To access engine codes turn the ignition ON and insert a jumper between terminals A and B. Terminal A is a ground, and terminal B is the diagnostic request line. Stored trouble codes can be read through the flashing of the Check Engine Light or on later vehicles the Service Engine Soon lamp. Trouble codes are identified by the timed flash of the indicator light. When diagnostics are first entered the light will flash once, pause; then two quick flashes. This reads as DTC 12 which indicates that the diagnostic system is working. This code will flash indefinitely if there are no stored trouble codes. If codes are stored in memory, Code 12 will flash three times before the next code appears. Codes are displayed in the next highest numerical sequence. For example, Code 13 would be displayed next if it was stored in memory and would read as follow: flash, pause, flash, flash, flash, long pause, repeat twice. This sequence will continue until all codes have been displayed, and then start all over again with Code 12. CLEARING CODES (EXCEPT CADILLAC) Except Riviera, Toronado and Trofeo: To clear any Diagnostic Trouble Codes (DTC's) from the PCM memory, either to determine if the malfunction will occur again or because repair has been completed, power feed must be disconnected for at least 30 seconds. Depending on how the vehicle is equipped, the system power feed can be disconnected at the positive battery terminal pigtail, the inline fuse holder that originates at the positive connection at the battery, or the ECM/PCM fuse in the fuse block. The negative battery terminal may be disconnected but other on-board memory data such as preset radio tuning will also be lost. To prevent system damage, the ignition switch must be in the OFF position when disconnecting or reconnecting power. When using a Diagnostic Computer such as Tech 1, or equivalent scan tool to read the diagnostic trouble codes, clearing the codes is done in the same manner. On some systems, OTC's may be cleared through the Tech 1, or equivalent scan tool. On Riviera, Toronado and Trofeo, clearing codes is part of the dashboard display menu or diagnostic routine. Because of the amount of electronic equipment on these vehicles, clearing codes by disconnecting the battery is not recommended. Riviera, Toronado and Trofeo (Non-CRT/DID Vehicles) — Using The On-Board Diagnostic Display System: First turn the ignition to theON position. On Riviera depress the OFF and TEMP buttons on the ECCP at the same time and hold until all display segments light. This is known as the Segment Check. On Toronado and Trofeo follow the same procedure, however, depress the OFF and WARMER buttons on the ECOP instead. After diagnostics is entered, any OTC's stored in computer memory will be displayed. Codes may be stored for the PCM, BCM, PC or SIR systems. Following the display of OTC's, the first available system for testing will be displayed. For example, 'EC?' would be displayed on Riviera for EOM testing, while on Toronado and Trofeo the message 'ECM?' will appear. The message is more clear on these vehicles due to increased character space in the IPO display area.
  1. Depress the 'FAN UP' button on the ECCP until the message 'DATA EC?' appears on the display for Riviera, or 'ECM DATA?' is displayed on Toronado and Trofeo.
  2. Depress the 'FAN DOWN' button on the ECCP until the message 'CLR E CODE' appears on the display for Riviera, or 'ECM CLEAR CODES?' is displayed on Toronado and Trofeo.
  3. Depressing the 'FAN UP' button on the ECCP will result in the message 'E CODE CLR' or 'E NOT CLR' on Riviera, 'EOM CODES CLEAR' or 'ECM CODES NOT CLEAR' on Toronado and Trofeo. This message will appear for 3 seconds. After 3 seconds the display will automatically return to the next available test type for the selected system. It is a good idea to either cycle the ignition once or test drive the vehicle to ensure the code(s) do not reset. Toronado and Trofeo (CRT/DID Equipped) — Using The On-Board Diagnostic Display System: First turn the ignition switch to theON position. Depress the 'OFF' hard key and 'WARM' soft key on the CRT/DID at the same time and hold until all display segments light. This is the 'Segment Check.' During diagnostic operation, all information will be displayed on the Driver Information Center (DIC) located in the Instrument Panel Cluster (IPC). Because of the limited space available single letter identifiers are often used for each of the major computer systems. These are: E for ECM, B for 6CM, I for IPC and R for SIR. After diagnostics is entered, any OTC's stored in computer memory will be displayed. Codes may be stored for the PCM, BCM, PC or SIR systems. Following the display of OTC's, the first available system for testing will be displayed. This will be displayed as 'ECM?'.
  4. Depress the 'YES' soft key until the display reads 'ECM DATA?'.
  5. Depress the 'NO' soft key until the display reads 'ECM CLEAR CODES?'.
  6. Depressing the 'YES' soft key will result in either the message 'ECM CODES CLEAR' or 'ECM CODES NOT CLEAR' being displayed, indicating whether or not the codes were successfully cleared. This message will appear for 3 seconds. After 3 seconds the display will automatically return to the next available test type for the selected system. It is a good idea to either cycle the ignition once or test drive the vehicle to ensure the code(s) do not reset.
20helpful
Date and Time Setting
You can download the manual for the 1260-3 which I guess is very similar from the link below: http://www.victortech.com/admin/images/products/1260-3%20manual.pdf Here are examples of the date & time setting: Set DATE to September 14, 2004 (09-14-04) 1. Depress the C or C/CE key.Your display with show 0. and the tape will read 0.C. 2. Depress the TIME/DATE key and hold until the display is flashing. 3. Enter the month, in our example, 09. Your display will show 9. 4. Enter the day, in our example, 14. Your display will show 914. 5. Enter the year, in our example 2004, as 04. Your display will show 91404. 6. Tap the TIME/DATE key to set the DATE. Your display will now show 09-14-2004. 7. To PRINT the DATE, depress the (#/S) key, your tape will show # 9.14.2004. Set TIME to 4:37 PM 1. Depress the C or C/CE key. Your display with show 0. and the tape will read 0.C. 2. Depress the TIME/DATE key and hold until the display is flashing. 3. Tap the TIME/DATE key to go to Time Mode. 4. Enter the hour, in our example 16 in military time. Your display will show 16. 5. Enter the minutes, in our example 37. Your display will show 1637. 6. Tap the TIME/DATE key to set the TIME. Your display will now show P 04-37-00 and the seconds will begin counting. 7. To PRINT the TIME, depress the (#/S) key, your tape will show #?04?37. Please update the question & let us know if the information given was useful to you - Good Luck!
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
