Question about LG GH22NP20 22x Internal DVDRW Retail Kit DVD±RW Dual Layer Burner
Drive not working. - LG GH22NP20 22x Internal DVDRW Retail Kit DVD±RW Dual Layer Burner
Posted by panwarrakesh on
  • Anonymous Jan 25, 2011
    how old is it and have you checked to make sure one of the ribbons or power cord didnt come loose
Brian Sullivan
  • LG Master
  • 27,725 Answers
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Jan 25, 2011
1helpful
2answers
I have a USB floppy disk drive that is not working in my pc
Windows 10 does not have floppy disk drive support for internally installed floppy drives. USB drives should work. I have a TEAC external that works just fine with WIN 10.
Floppy Drive support in Windows 10
My 4wheel drive doesnt work? What can I do or look at to fix?
4 wheel drive does not work - CarGurus
www.cargurus.com > Questions > Chevrolet > Suburban
CarGurusDec 17, 2009 - 4 wheel drive does not work - When I put the Sub in 4 wheel drive, low of high ... I want to "add" 4 wheel drive to my 95 1500 suburban w/ a 350.
My 4 wheel drive stopped working - CarGurus
www.cargurus.com > Questions > GMC > Sierra 2500
CarGurusJul 15, 2014 - My 4 wheel drive stopped working - After struggling with the 4 wheel drive ... sometimes in low sometimes in high, now it doesn't engage at all.
4WD not engaging all the time. - CarGurus
3answers
I need to get working non dell harddrives
Hard drives are hard drives. They will work in any computer..
3tb external imation expert d300 not working with windows xp
Windows XP does not have support for any disk-drive larger than 2TB. So, your 3TB disk-drive will not work. Upgrade your computer, or buy a 2TB disk-drive.
Dvd drive won't run but cd drive works fine
Check plug connections / swap cables and retry.
If it now works then cable is faulty.
If still no go then replace DVD drive.
Disc drive stopped working
A hard drive can stop working just like any other electronic device when it becomes faulty.
First go into the BIOS configuration and check if the hard disk is detected. If not it could be faulty.
Next re-seat the hard drive, it just may need connecting again to make proper electrical connection.
If it still does not work, then remove the hard drive and plug it into an USB hard drive adapter and connect it to a working computer's USB port. If this computer cannot see it as an external USB hard drive nor can you open the folders and files then the hard drive is definitely faulty.
To get the laptop functioning again, replace the hard drive, install Windows on the new hard drive together with the laptop's device drivers and your programs.
1helpful
Western Digital My Book Pro - Replace Disks
Same problem. This from WD Answer ID 1664:
Important: The user serviceable enclosure will only work with replacement hard drives from Western Digital. Inserting a non-Western Digital hard drive into the enclosure could cause damage or data loss.
So Hitachi drives will not work at all. After talking to tech support, it seems you have to have them send you a replacement disk in order for it to work.
I'm looking for a way around this since I want to upgrade my dual 500 G drives with dual 1 TB drives also. Maybe they throw something onto the boot sector that tells the MyBook controller what to do, who knows? The search goes on.
db
2answers
Simple Tech USB Drive will not work
I have a Simple Tech USB Drive that will not work. When you plug it in the lights blink, but you cannot access the drive. How do I fix the drive and get my information out of the drive?
1helpful
Verbatim 250GB External Hard Disk not recognized by PC
Almost always, when a USB drive doesn't assign a drive letter in MY Computer the issue is a Mapped network drive using the drive letter the USB drive is attempting to use.
With the drive connected, open DISK MANAGEMENT find the USB Drive, right click it and assign it an available drive letter.
Drive cd dirve not working
This device is not working properly because Windows cannot load the drivers required for this device. (Code 31)
Click Troubleshooter to start the troubleshooter for this device.
LG GH22NP20 22x Internal DVDRW Retail Kit DVD±RW Dual Layer Burner Logo
Top LG Computers & Internet Experts
Ekse
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
