hello, F2 04 Improper cartridge (destination error, life cycle error). Try to put back the old cartridge , see if F2 dissapears, or try to put in a new one. the toner cartridge seems to be the problem.
Well F2 error codeis on a variety of Sharp copiers, the F2 error code would normally be accompanied by a sub code that indicates the fault, You may please check out the following -
F2 with sub code 00 - Toner Sensor problem, ID pattern reading error;
F2 with sub code 02 - Toner Motor problem, check toner dispenser motor;
F2 with sub code 31 - Image Density error, Check the light level or the drum surface reflectivity;
F2 with sub code 32 - Drum Mark sensor, missing/dislocated mark or sensor faulty. Sensor cannot scan mark properly;
F2 with sub code 33 - grid voltage wrong, either too high or too low;
F2 with sub code 35 - grid voltage correction will not work during simulation;
F2 with sub code 37 - drum mark sensor adjustment required.
You may post further comments for more help or information......
During installation , use sharp ar205 developer and sharp ar021 toner cartridge. This shows you did not use developer or used the wrong ones, good luck.
Hello sir; F2 have a sub code, press print key to read the sub code, if the sub code is 04,then it means wrong cartridge,wrong country, you can try to reset it;
1, press "#", "interrupt", "c", "interrupt" keys.
2, enter 14 press start.
3, if it work, don't forget give me a good rating.
The F2-04 error code you are getting is that you are using the wrong toner.It may be form sharp,but it toner chips is different.Only the chips swapping at the toner back can help you.
