You can try by taking out the bios battery first it might of died on you theres also a ultimate boot cd you can find and download for free i had this problem before put on usb if you get to the bios screen see if it detects your cd drive once the batterys are out hold power button down for 15 to 30 seconds this should at least give you basic function drivers and make sure you have it detect your hardrive and move boot device to cdrom first then have windows cd in computer on reboot windows xp without sp3 probly wont detect a sata drivenot sure might have to use vista
According to your problem first make sure that the hard drive is OK and working fine. You can attach with another PC to be sure that the drive is OK. If the hard drive is working properly then change the SATA cables (data and power). Check that you have connected all the cables properly with motherboard, SMPS and hard drive. Make sure that the hard drive is motherboard supported. If it doesn't solve your problem then change the bios settings. Make SATA enabled in bios. Check the SATA mode in bios. Proper bios settings can make your drive working if the drive is OK. For proper bios settings you can take help from motherboard manual.
